B7800 stopped running
   / B7800 stopped running
Checked all wiring and it appears fine, I could have missed something however. Ordered a new fuel stop solenoid as a starting point. It may also be an issue with key switch or a dozen other darn things. I'll advise the solution once I get there.
Thanks to all,
Steve
   / B7800 stopped running #12
I'd replace the cut off first. Run a direct wire from the battery to test it. If the wire gets hot it's probably bad. Usually when they go bad they stop working...or get hung up in the middle somewhere. Should be an easy swap.
Good Luck,
Rob
   / B7800 stopped running #13
Kart, I bought a Workshop Manual for my B7800. I could fax some info. Let me know.
   / B7800 stopped running #14
Thanks to all,
Steve
Why not do some troubleshooting before throwing parts at it? Do you have a good multimeter? The solenoid can be tested for shorts and even bench tested. Can it be removed and run the machine to see if that is truly the isse?
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
1604 (A57192)
1604 (A57192)
