XJ 2025H just quit
   / XJ 2025H just quit
Still no luck. Can’t imagine that it would be so difficult to bleed air out of the system. A couple more observations that seem strange to me:
I hooked a hose from the filter input port to feed from an external supply anticipating filling it with fuel. It filled itself from the filter housing with 5 times more fuel that was in the bowl and the fluid level in the bowl never dropped. Almost overflowed so I tried bleededing.
I noticed that the 4 way connection for the return showed signs of weeping on all hoses. Not sure if was like that previous or not. I disconnected the return hose at the filter housing and got a good amount of fuel flowing back. That doesn’t seem right. Isn’t there some kind of check valve at the tank?
The original filter had a small O ring in the middle of the top of it. New one didn’t. So I reused the original. Hey LS- How about including it and rip us off for another couple dollars?
Anyway getting frustrated here as I have a ton of work to do with it…
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
