B7800 rear remote question
   / B7800 rear remote question #1
dirtdiggerdug
Southwestern Pa.
Kubota 7800
I have a Kubota B7800 with a BH. There are 2 hoses that run from the FEL valve to the rear of tractor. When these hoses aren't being used for the BH, they are connected into each other. I would like to add a rear valve to control a cylinder on my sickle mower This cylinder is used to raise and lower the cutter bar. Does anybody have a setup like this on there B7800? if so, what type or kind of valve do you use? Would appreciate any info I can get and thanks.
   / B7800 rear remote question #2
Doesn't have to be a b7800 or even a Kubota...the principle is the same on all modern tractors.
You need an open center, 4-way, spring return to center valve like THIS if you just want one spool. Then you need the proper QD's and you are all set.
Thanks Ken for the info. Just what I needed to know.
2015 CATERPILLAR 299D SKID STEER (A51242)
2015 CATERPILLAR...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
