B7800 Rear Axle leak
   / B7800 Rear Axle leak #1
SuperDave
Leduc Alberta
Kubota B7800
Has anyone replaced the rear axle seal on a B7800? I am wondering if this is something I can do myself, or if it requires any specialty tools. Any info. would be appreciated.
   / B7800 Rear Axle leak #2
You do have to remove the axles from the tractor! Then take them apart from the inside to get you to the seals. Why do they need replacement? Haven't seen them yet.
The seal is leaking slowly. I have a small puddle under the tractor every day. 2" in size.
I was just at my kubota dealer, and it seems to be a relatively easy repair. The axle assembly comes off with a few bolts, remove a c-clip and the axle will slide off. I think I will give it a try. Only a 20 dollar part.
   / B7800 Rear Axle leak #5
Pictures and play by play are always appreciated by the next poor sap that needs to do it.. :)
I have 680 hours on the tractor. Quite a bit of very cold operations since I live in Alberta and have a driveway 1 mile long. I don't know if the cold weather is harder on the seals. I'm guessing it is.
Year: 2020 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 190,820 Plate: Body Type: 2 (A51692)
Year: 2020 Make...
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
2011 Ford Transit Connect Cargo Van (A50323)
2011 Ford Transit...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2008 Ford F-250 XL (A50120)
2008 Ford F-250 XL...
2002 Western Star Trucks 4900 SA Truck (A51692)
2002 Western Star...
