Snow B7800 in the snow
   / B7800 in the snow #22
Yes I have a PHD and forks
I love it I have had it since this summer. It had done mor than I ever thought
The only thing I regret is not getting the ATI tach all and bucket. Oh and a Tooth bar is
a must have
   / B7800 in the snow
What brand/model is that phd, looks pretty good. I've got the ATI quick- attach, wasn't too expensive, considering how much time it saves.:D
   / B7800 in the snow #25
Timber said:
Is there a reason you think it should be under 600 pounds. Mine is over 800 pounds for my B7800. It is perfect so far. You can actually make a 55 gallon drum 1000 pounds. That is less than 1/2 the capability of the 3 point hitch
Sure you can make it as heavy as you want up to 1600 lbs. But with loaded tires that's all he needs.
   / B7800 in the snow #26
Oh that makes sense then. your right that would be plenty. I know that with 800 pounds that my hydraulics give out before my rears come off the ground
   / B7800 in the snow #27
Timber is always a great resource, greats pics, but I gotta ask - is that a Guinness on that first ballast picture????
   / B7800 in the snow #29
srl28 said:
could be a skidsteer plow too as I have quickattach. A :confused:
srl28, can you tell me more about your quickattach (on a b7800?)
   / B7800 in the snow #30
Timber, I noticed in the picture of the front of your tractor you have the detachable forklift prongs. Do they stay attached alright and work ok? I have been considering a set of them and wanted some opinions from somebody that has a set. I think they would be what I need as they would have to come off when the tractor is put back in the barn. I would appreciate your reply and anybody else's also. Thanks.
Huey-SE Indiana
2018 TAKEUCHI TL12V2 SKID STEER (A52707)
2018 TAKEUCHI...
2013 Fiat 500 Sport (A56859)
2013 Fiat 500...
UNUSED FUTURE HYD AUGER SET (A57193)
UNUSED FUTURE HYD...
2007 Anderson 25ft 7 Ton T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
2017 Freightliner 114SD Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
