B7800 hydraulics won't go down!?
   / B7800 hydraulics won't go down!? #1
vwkismet
So. NH
I have had my B7800 for about 8 months with no problems. I changed all of the fluids when I first got it in May (approx. 200 hours). Everything was fine after that. A couple days ago I took it out of the barn and neither the FEL or the rear 3-point will go down. Both will go up; the FEL will come down in float; but, neither will go down. No fluid is leaking and nothing is obviously wrong. I will obviously check all the hoses, but does anyone know what is wrong right off the bat?
Thanks, Michael in NH
   / B7800 hydraulics won't go down!? #2
Is the Hydrostatic transmission & the bucket dump working properly? I don't think the 3 point hydrolock knob will effect the loader.
Yes. Both the transmission and dump seem fine.
   / B7800 hydraulics won't go down!? #4
vwkismet,
First off I'd suspect a return line/power beyond quick connect is not seated properly resulting in a blockage for the return flow, second I'd make sure the 3ph lever is not engaged in the Full/Up position as this can effect the FEL....
You're obviously experiencing return flow problem back to tank if they go up but not down....Hope this helps....:)
Bill
wdchyd said:
vwkismet,
Bill
Thanks for the advice. As you suggested, the 3ph lever is out of adjustment and is usually engaged trying to lift the 3ph, thus blocking the return. When I get the 3ph to stop lifting, the FEL works fine.
So, I am going to start searching, but if anyone can point me to a quick and easy tutorial on how to adjust the 3ph lever I would very much appreciate it!
   / B7800 hydraulics won't go down!? #6
Nice work Michael....I've seen this before with the 3ph lever (adjustments and operator error)....Enjoy that B7800 with all this snow ......:thumbsup:
Gehl 1870 Round Baler (A50514)
Gehl 1870 Round...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
2010 Toyota Tundra (A50323)
2010 Toyota Tundra...
2014 Dodge Avenger Passenger Car, VIN # 1C3CDZAB4EN223470 (A50324)
2014 Dodge Avenger...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
International 720 6-Bottom Plow (A52128)
International 720...
