B7800 headlights
/ B7800 headlights #1
drzmatt
Central NY
Kubota 7610
Are there brighter bulbs that I can put in my 7800 without melting anything down. The factory bulbs are completely worthless! My 7610 had much better lighting.
/ B7800 headlights #2
If you have a FEL on your tractor, most any bulb is going to be almost worthless. At least that is what I have found. I have a 7800 and mounted a couple 55 watt forward pointing lights on a piece of angle steel and attached that to the ROPS. It does make a big difference. I have one 55 watt flood light pointing to the rear. The front and rear are on separate switches, and I do not use the factory headlights. I seldom run the front and rear at the same time. If so, only for a very short time. I have not upgraded the alternator, but we'll see if it becomes necessary. Hope not.
If you don't have a FEL, then I don't know about brighter bulbs. However, this is my first tractor, so I have nothing to compare it to. With the FEL on the ground, the factory headlights seem acceptable. Just my take. Good luck.
/ B7800 headlights #3
There is a thread here where someone converted their BX lighting to HIDs and discusses the issue of heat.
Search for HID /forums/images/graemlins/grin.gif
/ B7800 headlights #5
Yes they are called Blazer bulbs and they are at auto zone and yes they make a huge difference and no I haven't melted anything yet
/ B7800 headlights #6
I recently purchased 2 Blazer bulbs at Autozone and immediately dropped one on the floor when I went to install it. No problem, I'll just stop back at Autozone and pick up another. Well, I went to Autozone the other day and they pulled all the bulbs from the shelf and sent them back to who-knows-where. I asked and they said they no longer carry them so does anybody know where else I can buy some?
Terry
/ B7800 headlights #7
They have the 50W Blazer bulbs at some WalMart stores; the fit the cheap driving/fog lights that don't use a Euro H1 or H3. I used to put them in backup lights on my vehicles but now use a better (and more expensive) industry # 795. This bulb has the same base as an 1156 bulb but has a smaller quartz glass envelope. These are also 50W but are a good bit brighter than the 50W Blazer due to the more efficient halogen bulb.
EDIT: If your tractor has the odd dual filliment bulb, they are the same as many 4 Wheelers (ATV's) use. They come in 27 and 35 watt. Prob won't be any cheaper at motorcycle shop but may have a larger choice.
/ B7800 headlights
Do they look like the attachment? Do they get too hot?
/ B7800 headlights #9
The pic is a little small. The 795 bulb has the same base as the blazer bulb which is the same size as the standard 1156 auto bulb. Do a search for "industry # 795 lamp" although it is hard to compare size as most pics just show a bulb on a blank background with nothing to reference size. The pic I saw made it look like a flashlight bulb. These bulbs are used in emergency lighting to replace the 27W/32 candlepower 1156 or the 50W 1195 with a brighter substitute. As for heat ; they do prob get hot but the smaller glass envelope leaves more clearence.
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
2013 INTERNATIONAL DURASTAR 4400 6X4 FLATBED TRUCK (A64278)
2013 INTERNATIONAL...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2007 Rhodes AS3573 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2007 Rhodes AS3573...
1993 International 4900 Ram Rodder Combination Sewer Jetter Vacuum Truck (A64194)
1993 International...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
