B7800 Grease Points
   / B7800 Grease Points #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I know the obvious points ( grease nipples) on the FEL and the 3 point are their others?
   / B7800 Grease Points #4
   / B7800 Grease Points #5
If you sit down next to the tractor on the same side as the HST pedal just rock the pedal by hand and you will see the pivot point below the floor board. The is a grease fitting on that one.
CAUTION!!! Be sure to shot of tractor while doing this. :thumbsup:
Got It! thanks for everyones help.:thumbsup:
   / B7800 Grease Points #7
There is also a grease fitting on the brake pedal pivot, which also under the deck on the right side. The HST pedal pivot is supposed to be greased every 10hrs.
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
