B7800 Grease Points
/ B7800 Grease Points #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I know the obvious points ( grease nipples) on the FEL and the 3 point are their others?
/ B7800 Grease Points #4
/ B7800 Grease Points #5
If you sit down next to the tractor on the same side as the HST pedal just rock the pedal by hand and you will see the pivot point below the floor board. The is a grease fitting on that one.
CAUTION!!! Be sure to shot of tractor while doing this. :thumbsup:
Got It! thanks for everyones help.:thumbsup:
/ B7800 Grease Points #7
There is also a grease fitting on the brake pedal pivot, which also under the deck on the right side. The HST pedal pivot is supposed to be greased every 10hrs.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
121A (A63745)
121A (A63745)
Alligator Statue (A64557)
Alligator Statue...
