B7800 Grease Points
/ B7800 Grease Points #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I know the obvious points ( grease nipples) on the FEL and the 3 point are their others?
/ B7800 Grease Points #4
/ B7800 Grease Points #5
If you sit down next to the tractor on the same side as the HST pedal just rock the pedal by hand and you will see the pivot point below the floor board. The is a grease fitting on that one.
CAUTION!!! Be sure to shot of tractor while doing this. :thumbsup:
Got It! thanks for everyones help.:thumbsup:
/ B7800 Grease Points #7
There is also a grease fitting on the brake pedal pivot, which also under the deck on the right side. The HST pedal pivot is supposed to be greased every 10hrs.
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
UNUSED RAYTREE REDM32 HYD EXCAVATOR MULCHER (A65055)
UNUSED RAYTREE...
INGERSOLL RAND VR-530C TELESCOPIC FORKLIFT (A65053)
INGERSOLL RAND...
78in Heavy Duty Hydraulic Grapple Rake Skid Steer Attachment (A64553)
78in Heavy Duty...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
