B7800- Engine RPMS to Remote Hydraulic GPM ??
   / B7800- Engine RPMS to Remote Hydraulic GPM ?? #1
z0lt3c
Hunterdon Cnty, NJ
2020 Kubota BX2380
Hey All-
Now that my Woods backhoe is all up and operational, I am wondering what the proper engine RPM to use is to generate max GPM out of the hydraulic rear remotes powering the backhoe.
Does the GPM output of the tractor increase with more engine RPMS?
Would there be a reason to run the backhoe at a higher vs lower RPM speed? Or do I just find the sweet spot and lock it in for all use-cases?
Any other tips or tricks in regards to tractor settings before using the hoe? Do you guys lift the front wheels w/ the FEL?
Thanks,
   / B7800- Engine RPMS to Remote Hydraulic GPM ?? #2
Short answer is Yes...Faster RPM's equate to higher GPM's. Also when the GPM's increase so does the speed at which the hoe operates, so you need to find a happy medium.
Beginner operators will benefit from slower operation so they are not slamming the boom from side-to-side.
There is no correct answer-you need to experiment and fing what works for you.
   / B7800- Engine RPMS to Remote Hydraulic GPM ?? #3
The B7800 also has a Hydro control valve, just below the seat between your feet.
It controls the flow rate... faster.... slower. So depending on your RPM you can control the rate and then determine from system reaction on your BH.
Then figure out what works best for you, RPM, Flow and hydro power.
Cheers and have fun!
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
5004 (A55851)
5004 (A55851)
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
