B7800 Dynamo Replacement
/ B7800 Dynamo Replacement #1
Kevin Staton
Kubota B7800
I'm replacing the dynamo on my B7800 after the bearing locked up and much squealing and smoke was released (belt). I have the new dynamo but have a very simple question. The two wires coming from the dynamo are the same sky-blue color and have the same bullet-type connectors as do the wires on the tractor. Does it matter which wire from the dynamo goes to which wire on the tractor?
I suspect that since the dynamo is producing AC current that it doesn't matter. But, I also don't want to damage a very expensive part.
Thanks in advance,
Kevin
/ B7800 Dynamo Replacement #2
You're correct. It produces AC current, so the wire position don't really matter, hence the same color and terminals. Then the rectifier converts it to DC to charge the battery.
Thanks, ptsg! In all the info I found on the B7800 Dynamo no one mentioned the wiring.
For anyone reading this thread in the future, I installed the dynamo, plugged in the wires and everything worked. And, there is 0% chance that I would randomly hook up the wires correctly if they had to be done in a specific configuration.
/ B7800 Dynamo Replacement #5
Nice. Thanks for the update. Some tractors have a 3 wire dynamo, others 2 wire, the principle is the same.
/ B7800 Dynamo Replacement #6
LOL… I think there was a 50% chance you could have gotten it wrong, if the wires had needed to be hooked up in a certain way. Since there were only two wires…
In any event, congratulations on the successful installation!
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 6X4...
Concrete Mixer (A62613)
Concrete Mixer...
Caterpillar TL1055D (A62177)
Caterpillar...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
