B7800/B3030 - Large enough for heavy loads?
   / B7800/B3030 - Large enough for heavy loads? #21
As I re-read this, I had another thought.
You profile does not list where you are located and you did not mention if where you need to move these pumpkins is flat or hilly.
This could be VERY crucial in your choice. If you have a slightly hilly area, (up/down & esp side to side), A larger L would def be preferred. If your land is pretty much flat, then I'm sure a 7800 or 3030 (a tad bit heavier w/slightly more lift capability) would do the lifting you require with ease.....either through the loader or the 3pt lift. With either choice you'll need a decent counter weight in the rear (or a carry all with another pumpkin back there), though the loader should work fine as a front ballast if using the 3pt, to lift.
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2014 Jeep Compass 4x4 SUV (A55853)
2014 Jeep Compass...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
