B7800 3-pt conversion
/ B7800 3-pt conversion #21
Just to update: I installed the telescopic adjusters on the B2620 this morning with no issues. It's very easy to do yourself. The hardest step is installing the stabilizer brackets, and even that was pretty easy. You have to loosen the bolt underneath the rear PTO to free up the pin that holds the lower links. I tapped it far enough to one side to replace the stabilizer bracket and then tapped it in from the other direction until I could replace the other side. I don't think you can slide this pin right out without pulling a tire (which is unnecessary). Great upgrade.
