B7610 will not start
/ B7610 will not start #1
sven1277
Gales Ferry, CT
Kubota B7610
My operator went to start the tractor last storm and nothing. Usually it means the pto lever isn't perfectly in neutral. That was fine. The starter does work when the posts are jumped. When turning the key, on occasion, you can hear a click from inside the steering column, but it doesn't make a difference. I'm thinking possibly a bad ignition switch or safety interlock. Other thoughts?
/ B7610 will not start #2
Yep. You've confirmed the battery is good. When you jump posts does the tractor start and run?
/ B7610 will not start #4
Its usually the operators "seat present switch" or PTO.. meaning the seat safety switch is usually the culprit..
The reason it didn't start when jumping the starter is, the fuel shut off solenoid on the back of the injection pump, had no juice..[12v]
IF you REALLY NEED the equipment>> remove the sol. or figure out how to jump it.
Its usually a 3 wire solenoid..
IF its a 2 wire.. that's easy.. + on 1.. - on the other.
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2026 Spirit All Terrain Electric Bicycle (A61569)
2026 Spirit All...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2018 Freightliner Cascadia 126 Sleeper Truck, VIN # 3AKJHHDRXJSJW6608 (A61165)
2018 Freightliner...
