B7610 and TSC Auger
   / B7610 and TSC Auger #1
DennisArrow
Platinum Member
Sugar Valley, Ga
Iseki TL 2300, Kubota RTV, Kubota B7610
My new to me B7610 with less than 500 well maintained hours is quite the machine for me. Does everything I have needed it to do really well.........Moved 4 dump loads of crushed chert ore for fill, 5 loads of crusher run and spread it, maintains with blade 1/2 mile of gravel, bush hog and finish mower and on and on........Anyway, I have the need for a 3PH PHD, post hole digger, that TSC, Tractor Supply, is gonna have on sale in the next couple of weeks with 10% off. The question for folks who have used this combination or have knowledge of the subject is:
Will my 19 HP PTO drive a 9" or even a 12" auger in clay? Usually damp clay not packed like a rock
Will my 3PH arms raise high enough for this specific TSC PHD/Auger to work?
Thanks for the thoughts........God bless.......Dennis
   / B7610 and TSC Auger #2
Yes no problem!
I have the b2920 with 21pto HP and it turns a 12" at just above idle.
What you need to watch for is lift height in relation to your tractor. Ie; make sure to get a subcompact or compact phd
Hope this helps
Thanks ericher.............Good to KNOW that 21 HP will do the job so well. That totally reassures me that the power will be there. NOW to figure out if the arms will allow the PHD to go high enough. I called Speeco, the manufacturer of many implements for TSC and asked an engineer about the arms subject. Was truly funny as he had no idea if it would work and advised it was a "trial and error" process for fitment. He did assure me that the model that TSC markets is made for Sub and Compact tractors..........
Sure would love to hear from folks on here that have experienced this problem........God bless.....Dennis
   / B7610 and TSC Auger #4
I was facing a similar problem with my B7610, so I bought something to make sure the PHD would be high enough off the ground - an M4700. :)
   / B7610 and TSC Auger #5
We've got the experience and the PHD that you're looking for!!
Our Everything Attachments Compact Post Hole Digger is made just for subcompact and small compact tractors like the BX and B Kubotas. They have a taller hoop and longer boom so you will have enough lift height. Also, they use a 48" long auger with a 2" shaft. Our post hole diggers ship free to your home within 1,000 miles of Newton, NC via UPS or Fed-Ex ground. If you're outside of our free shipping zone, shipping is generally very reasonable.
   / B7610 and TSC Auger #6
I have an EA Box Scraper, Pallet Forks and Root Grapple. All of excellent quality and work well. I'll will be buying a Post Hole Digger from them this spring. The stuff I bought from TS has ended up being returned when it broke. Just my 2 cents.
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2008 FORD F-750(INOPERABLE) (A50854)
2008 FORD...
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
