B7510 vs BX2200
/ B7510 vs BX2200 #1
rlcokc
Looking at used. I don't see alot of difference other than BX2200 newer model. Equiped with FEL and brush hog or box blade around $10,000--little less. Would kindof like to have mmm but don't seem to be on many of the models. Which is best and why? Am I missing something?
/ B7510 vs BX2200 #2
Welcome aboard.
Sometimes when we type, we think faster than our finger can go.
Your question(s) are a bit jumbled. Try it again, please. The B7510 is an awfully lot larger machine than the BX2200. Both are from circa 2002 era and both are just fine machines. Although, they are pretty darn different in intended use.
MMM's are pretty common with BX's and less so with the larger B model tractors. Also, if any machine is missing a mowing deck, these replacements can be somewhat difficult to locate and quite pricey. If you must have an MMM, I might suggest you look at tractors with them installed already. Check its condition, quiet operation, smoothness of bearings and cleanliness.
If a tractor is 8 years old, and the previous owner trashed/wore out the deck, due to heavy use coupled with very poor maintenance, it will be "missing." Also, Sometimes things get "broken apart" in the selling process. Sometimes, the MMM never existed on a particular tractor, ie, the previous owner didn't desire one.
/ B7510 vs BX2200
Thanks for response. My post was hurried. The 7510 I'm looking at has box blade and FEL with no mmm. The BX2200 has FEL and mmm. As I understand it both are approximately 21 horse. The response would indicate the 7510 is larger and capable of greater workload-lift more. I really don't believe I would do a great deal of mowing with belly mower and have a small brushhog whick I could attach to 7510. Would like the hydrostatic transmission that is on 2200 as this 7510 not equipped. Is the price in ballpark as both have approximately 170 hours. They both appear to be in good condition and have been stored out of the weather. Will look at 7510 this week. Any additional thoughts or caveats on what to look for. Thanks
Rod
/ B7510 vs BX2200 #4
170 hours is very, very light usage on either of these. As you will see, horsepower isn't the issue between the two. Both will have 22/23 rated hp, with the BX having less at the PTO than the B model.
The B is simply a much larger tractor. It's bucket is larger, its tires are larger. The B has approximately twice the ground clearance and should be priced at significantly more dollars. $6000 plus or minus on the BX2200, and $8500 plus or minus on the B7510. (Those are low figures. A spotless machine could fetch up to $1500 more on the BX and $2000 more on the B, depending on attachments included. But that is all. Paying more might mean you'd be better off looking elsewhere or looking new with warranty and zero percent financing.
Look for a well cared for, almost pampered machines. Get a history of fluid/filter changes. Look for damage, dents, fluid leaks, etc. Only you can decide whether a BX or a B best suites your needs. This is based on turning radius requirements of your property and your planned use.
Finally, be very, very careful if you are responding to Craigslist or similar. If the price is too low, (from what I stated above) it is absolutely, most likely, a scam. Never give anyone a dime without laying your own eyes on the machine. The old "it is in South Carolina and will be shipped to you" trick is a total scam.
/ B7510 vs BX2200 #6
If you are looking to use the tractor on more uneven terrain, do more heavy lifting and the area you plan to bush hog is fairly open you should choose the B7510. However I think a manual shift tractor can be a bit more to get used to. If you drive a manual car and don't mind it then no problem.
I agree with the previous statement that they are both very good machines but were intended for slightly different uses.
How big is the acreage you plan to take care of? What are the chores you hope to accomplish?
/ B7510 vs BX2200
Have 30 acres--10 clear and will mow field that is about 2 acres, rest the wife mows with Ferrell zero turn. I would use tractor to clean up between trees-move undergrowth and mow trails thru trees. Had B7200 which I haven't used in years--I let alot of proprety go back to wild. Reallly want front end loader because I've always wanted one and have different jobs I can use it on--leveling driveway, moving/clearing snow altho in Oklahoma not a priority, and just moving dirt.
I spoke with local Kubota dealer and he is trying to sell me a B2320 which comes with loader, box scraper and 48 mower all for the zero finance of $14,000. Is that close--I will get quote from Messick b4 I do anything. Wife will not be enthused about new tractor but I pretty much get what I want since I'm 60. I do appreciate thoughts and comments and any additional suggestions would be appreciated.
Rod
/ B7510 vs BX2200 #8
I had a B7610 before my current tractor and liked it a lot but it had no cab. At the time I looked at a BX but thought the smaller tires and less ground clearance would be a problem for me when cutting trails through the forest. Since you already have a machine for finish cutting I would suggest the B would be a better choice for you. Another thing I wasn't aware of when I looked at the BX but have seen mentioned on this forum is that the BX has a plastic cooling fan underneath that is suceptible to damage from undergrowth. You could do a search about the cooling fan and find more information.
/ B7510 vs BX2200 #9
I really love my BX2660 and loved my BX2200, but when you take mowing out of the equation, I can see non justification for the BX and would uniformly go with the B.
/ B7510 vs BX2200 #10
Rod
That is a very, very good price, if it is an HST tranny. (hydrostatic) Although, I cannot imagine a 48" mower, unless it is a rear finish mower? Surely not a belly mower? I would think a B2320 would come with a 60" belly mower. You would enjoy the ease of a rear mower, if you don't have a cluttered lawn, with lots of obstacles, that is the way to go.
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2015 Ford F-150...
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
Case SV280B (A60462)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59906)
2016 FREIGHTLINER...
2019 Ford F-350 (A55973)
2019 Ford F-350...
