B7500 Engine Valve Clearance
/ B7500 Engine Valve Clearance #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
I just finished the 750 hour service on my 2003 B7500. So far, I have been able to do all the service myself. The 800 hour service requirement includes adjustment of engine valve clearance. The manual says, "Consult your local KUBOTA dealer for this service." I have never adjusted valves on any type of engine, so I am inclined to have a Kubota dealer do the work, but I hate the idea of having to transport the tractor and have it unavailable for a period of time that I do not control.
Has anyone done this adjustment themself? Is it something that I should not even consider? I do not have a WSM, so I have not read the instructions nor seen a parts diagram.
For those who have had this work done by a Kubota dealer, roughly how much did the dealer charge and how long did the dealer have your tractor?
Thanks, in advance for any insights! Rusty
/ B7500 Engine Valve Clearance #4
It's easy, hardest part is probably getting to the valve cover and valves. When using the feeler gauge and adjusting, you have to really "feel" for the adjustment, by this I mean the valve springs are not that heavy, when adjusting a valve you can start pushing the valve down with realizing (and I did this for a living).
All said even at 800-900 hours they are probably not out of adjustment and wouldn't be high on my list...unless you can hear a lot of loud tapping under the valve cover at idle. If you take the tractor into the dealer for something else, have them do it if you are not comfortable.
the setting on my L is the same if I recall... .005-.007"...COLD.
Good luck,
Rob
/ B7500 Engine Valve Clearance #5
Rob,
Don't valves with solid lifters get QUIETER, no louder, as the valves wear in and the clearance decreases?
KB
/ B7500 Engine Valve Clearance #6
Rusty, Valve adjustment is not difficult to do but if you've never done it, you can create a real problem. I suggest you find a buddy or acquaintance that has done a valve adjustment before and enlist some help. Once you have a feel for using feeler gages and understand the principles of what you're doing you'll have no problem next time.
/ B7500 Engine Valve Clearance #7
Killer_B said:
Rob,
KB
All the ones I worked on get louder...IE wear, more clearance, more tapping noise. When I reset them they were always lose. But with the spec on a Kubota at .005-.007, and you are at .010, not a big deal IMO. If for some reason a valve tighens up, again, I've neer seen that...ever, that would be bad news.
As mentioned if you know a little of what you are doing, go for it, otherwise it might end up worse than when you started. But that's easy to double check, just roll the engine over by hand and when the valves stop moving for a quarter turn or so, clockwise from the front.. (I'm not getting technical here... :D) then double check.
Good Luck,
Rob
/ B7500 Engine Valve Clearance #8
Getting TDC (Top Dead Center ) is probably the hardest to get I would say and if ya don't how to do this I would suggest help from a mechanic friend so you can do it yourself next time.
A WSM is something that would help and ya many need it down the line for something else.
Rob, KB, Harry, Al (wushaw) - Thanks for all the help! I'm feeling alot better about taking this on. My son has good, natural mechanical sense and will walk me through the check and adjustment, if required. I've delayed buying the WSM for over four years. I guess it is time to buy. My mowing for this year is just about done, so hours will be accumulated mainly depending on snow fall. It may be spring now before 800 hours comes up. I will try to report how it goes. Thanks again, to all!!! :) Rusty
/ B7500 Engine Valve Clearance #10
Rusty, my B7500 is due for a valve lash check and was wondering if you ever ended up DIY'ing yours and whether you thought it was the right decision? I'm having the same debate about doing it myself or taking to Kubota dealer. I'm fairly mechanical and used to do valve adjustment on my old Triumph motorcyle years ago.
Ron, I now have 1,049 hours on my B7500 and still have not done the valve check. Please let me know what you decide to do, and what you or your dealer find.
/ B7500 Engine Valve Clearance #12
1*All said even at 800-900 hours they are probably not out of adjustment and wouldn't be high on my list...
Good luck,Rob
1*So wonder why Kubota says 800 hours?
1* I suggest you find a buddy or acquaintance that has done a valve adjustment before and enlist some help.
1*Good point.
1*I would suggest help from a mechanic friend .
1*You mean like my next door neighbor who's a diesel mechanic?
* Please let me know what you decide to do, and what you or your dealer find.
*Keep us all posted about yours also.
/ B7500 Engine Valve Clearance #13
Who knows. Normal wear and tear. They will only get slightly more loose because of wear. But if you are not sure how to do it, just leave it. Usually close is good enough, considering you almost need 3 hands to tighten and check at the same time. :p
/ B7500 Engine Valve Clearance #14
Good Luck,
Rob
Hey Guys,
I am new to the forum, but have been reading for several years. I finally pulled the valve cover off my B7500 at 1069 hrs and this is what I found. #1 exhaust was .01 and intake was .0005, #2 exhaust was .009 and intake was .002, and #3 exhaust was .009 and exhaust was .002, so on my tractor valves went in opposite directions if they were set at factory .0059 correctly to start with. I bought tractor new in 2002 so I am the only one to touch it. I set them all back to .006.
Hodge64 - Thanks for sharing your findings. I am about ready to do my 3,000 hr service, and have still not checked my valve clearances. I pray the factory did a good job.
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2025 32in. Tilting Bucket Mini Excavator Attachment (A59228)
2025 32in. Tilting...
2019 Deere 35G (A53317)
2019 Deere 35G...
2019 Chevrolet Silverado 1500 RST 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
2016 Komatsu HM400-5 (A60352)
2016 Komatsu...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
