B7300 Temperature Gauge
/ B7300 Temperature Gauge #1
skent
Platinum Member
Westminster, Maryland
Kubota B7300
Some of the early models of the B7300 didnt have a Engine Temperature Gauge. They use a "steam whistle" type of alarm. Only problem is the cooling system need to be air-tight (so escaping steam goes through the Whistle). This wouldn't be the case with a ruptured hose.
I played around with the idea of adding a temp limit switch (like thats inside a coffee maker) and wire it to a warning light(less than $20) , or even adding an aftermarket temp gauge below the instrument panel (less than $40).
But the temptation was offset by the age of the tractor (less than 200 Hrs) and not wanting or ruin the "lines" of the Instrument cluster.
TractorByNet.com to the rescue. I posted a message several days ago and got replys on the "B7300 updrade Cluster". I'm guessing the temperature issue got to Kubota and they put together a drop-in replacement cluster for less than $200.
At first I thought that was a tad too much $$$, but when you realize the value of the tractor, the cost of a replacement engine, and lowering the resale value by adding "boogered-up" devices, It was a cheep price to pay.
I ordered the kit, got it in 3 days, took 15 minutes to install the sender (plug in the back of the Cyl head comes out - sensor goes in) and snap in the new cluster w/Kubota OEM Temp Gauge!
My Uncle (Rest his soul) always told me "Don't buy chicken S--- , if you expect it to taste like chicken salad" .
Great Site- Great People Thanks.
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
1986 Ford 7710 Tractor (A66285)
1986 Ford 7710...
