B7200 HST water pump replacement questions.
   / B7200 HST water pump replacement questions. #1
Driver57
Maine
Kubota B7200HST
I have a 1986 B7200 that has suffered a water pump failure. Symptom was a screaming belt. Small leak from under the pump. Fan would not turn until the motor was turned off, at which time it would turn for a split second just when the motor stopped. I loosened the belt. Fan would turn with a great deal of difficulty. Alternator spins quietly and smoothly.
I found this kit on Ebay and want to know if this is what I need. There are others but it seems like a good time to replace the thermostat and smaller hoses. Any tips appreciated.
Thanks in advance,
Mike in Maine
New Kubota B72D B72E B72HSTD B72HSTE WATER PUMP with Hoses & Thermostat | eBay
   / B7200 HST water pump replacement questions. #2
Looks like everything but the bottom hose, While the cooling system is empty I’d sure replace all the hoses, shouldn’t be hard to find a bottom hose.
   / B7200 HST water pump replacement questions. #3
For what it's worth, I replaced the water pump on a B6200 a few years ago, and I think it all looked about like that. Can't remember anything I needed that isn't pictured there.
Thanks guys.:)
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
1607 (A57192)
1607 (A57192)
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
JCB 190 ROBOT SKID STEER (A60429)
JCB 190 ROBOT SKID...
John Deere Gator (A53317)
John Deere Gator...
