B7200 Electrical Problem w/ gauges
   / B7200 Electrical Problem w/ gauges #1
kimbass
Hi folks, my '86 B7200 HST has developed an electrical problem with the fuel gauge, headlights, and Charge/Oil pressure idiot lights. They don't work! (Tach and hour-meter are OK as are rear blinker lights). This began as an intermittent problem--they worked sometimes and sometimes they didn't. Now they are consistently not working. I've checked every connection I can reach behind the instrument cluster cover and cleaned every ground I can find. My operators manual must be a 10th generation copy because the wiring diagram is blurry and hard to follow. Any ideas?
Thanks!
Thank you KennyV--I have yet to check the fuse connections...once I find them. It's a great thought. I appreciate it.
   / B7200 Electrical Problem w/ gauges #4
I wonder if it might have something to do with the key switch. I believe the blinker lights work whether or not the key is on, but the rest of the dash lights, I believe turn off with the key. Plus the engine does not need the key to be on to run either. In fact I believe the only thing the run position on the key is for the charging system and the dash lights. I don't have my WSM (Work Shop Manual) anymore so this is about the best I can do.
Good Luck. :)
John Deere Gator (A53317)
John Deere Gator...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
yellow ball Trailer (A56859)
yellow ball...
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
