B7200 Electrical Problem w/ gauges
   / B7200 Electrical Problem w/ gauges #1
kimbass
Hi folks, my '86 B7200 HST has developed an electrical problem with the fuel gauge, headlights, and Charge/Oil pressure idiot lights. They don't work! (Tach and hour-meter are OK as are rear blinker lights). This began as an intermittent problem--they worked sometimes and sometimes they didn't. Now they are consistently not working. I've checked every connection I can reach behind the instrument cluster cover and cleaned every ground I can find. My operators manual must be a 10th generation copy because the wiring diagram is blurry and hard to follow. Any ideas?
Thanks!
Thank you KennyV--I have yet to check the fuse connections...once I find them. It's a great thought. I appreciate it.
   / B7200 Electrical Problem w/ gauges #4
I wonder if it might have something to do with the key switch. I believe the blinker lights work whether or not the key is on, but the rest of the dash lights, I believe turn off with the key. Plus the engine does not need the key to be on to run either. In fact I believe the only thing the run position on the key is for the charging system and the dash lights. I don't have my WSM (Work Shop Manual) anymore so this is about the best I can do.
Good Luck. :)
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
1968 Oliver Model 1850 2WD Tractor (A56438)
1968 Oliver Model...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
