Oil & Fuel B7100HST fuel filter problem
/ B7100HST fuel filter problem #1
Anonymous Poster
Epic Contributor
Several weeks ago my B7100HST (approximately 100 hours) began losing power and after diagnosing the situation, I determined that it was the fuel filter. I changed it out and, following the directions in the (flimsy) manual, proceeded to bleed the lines, etc. In the process, I tightened one of the bleeding screws too tight and it broke off. Now, after buying new screws (bolts), how do I get the broken one out? Also, I can't get it to start again. Is there something that I am overlooking or am I just dumb? Any assistance will be appreciated.
/ B7100HST fuel filter problem #2
Are you talking about the bleeder screws on the filter housing? If you are, the easiest solution is buying a new housing. I'm assuming your dealer won't stock that, since they rarely get replaced. In that case you will have to use some form bolt remover like an ez-out or something similar. As far as not starting you still have air in the system. I have never used the bleeder screws on the housing to bleed the system. I just leave the bowl loose and open the petcock then tighten the bowl after alll the air is out. Then I loosen the bleeder screw at the injection pump. Since you have tryed to start the tractor with with air in the system you will probably need to loosen the injector lines at the injectors and crank the engine until all the air is out of the lines.
Brian
/ B7100HST fuel filter problem #3
Won't start could be air still in line. On an older Perkins, I could let er start on a sputter and <font color=red>"bleed"</font color=red> on the fly. Couple of oz. splash on side of <font color=blue>COLD</font color=blue> engine would be the result.
I prefer the tappered square "easy out" for removing <font color=red>broken bolts</font color=red>. Start as small as possible and go to larger size to relieve tension against the threads.
Nothing dumb about it. You will after graduation, be a member of the <font color=green>"Get a Smaller Wrench Next Time"</font color=green> club. Welcome aboard. /w3tcompact/icons/laugh.gif
Come back if you need details.
"What is a weed? A plant whose virtues have not yet been discovered."
Ralph Waldo Emerson (1803-1882)
/ B7100HST fuel filter problem #4
Hawgee is right, use the square easy outs, but get good ones. (A couple of extra bucks on a good tool you can use again is probably cheaper than a new housing.) I've never broken a square easy out, but I've twisted quite a few of them. The spiral jobs are always breaking.
SHF
Thanks for the information. One more question...when does one know when all of the air is out of the system?
/ B7100HST fuel filter problem #7
one of my favorite tricks is a reverseing drill bit. snap on sells them. when the bit bites it will remove the broken bleeder. there is nothing worse than a broken easy-out.
/ B7100HST fuel filter problem #8
It will run when the air is gone. Air compresses. Don't look for it to flow in this case. If a bubble is not large enough to let the high or low pressure diesel past, "air lock". It will be found at a high point in the system. You are gonna get wet. I go for the last connection at the injectors if you've really sucked a lot of air. With lines open, you must provide pressure or turn engine over. I never did ask if this was a self primer, now did I.
As to the statement that reads, "I don't know of anything that is worse than a broken easy out". I can think of very expensive fuel bodys, pump bodys, busted knuckles and elbows. I renew my "Smaller Wrench Club" card from time to time myself. /w3tcompact/icons/smile.gif
/ B7100HST fuel filter problem #9
Besides, collecting tools and toys is all part of the game.
"He who dies with the most toys wins". /w3tcompact/icons/wink.gif
SHF
2014 John Deere 650K LGP Crawler Tractor Dozer (A64553)
2014 John Deere...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2007 Dodge Ram...
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
