B7100 Valve adjustment spec's?
   / B7100 Valve adjustment spec's? #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
What are the spec's for B7100 valve adjustment?
I saw 0.006 mentioned elsewhere but this shows 0.008 for both:
Kubota Engine Specifications
Seems straight forward - do it completely cold, remove valve cover, orient to valve completely closed, then adjust.
   / B7100 Valve adjustment spec's? #2
Workshop manual says .006 to .008 inch for both with engine cold with piston at TDC on compression stroke.
thanks, got it done today. appreciate it! didn't get to fire it up as i'm waiting to seal the radiator.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Kubota U55-4 (A57148)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A56860)
2025 Kivel 48in...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
