B7100 Valve adjustment spec's?
/ B7100 Valve adjustment spec's? #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
What are the spec's for B7100 valve adjustment?
I saw 0.006 mentioned elsewhere but this shows 0.008 for both:
Kubota Engine Specifications
Seems straight forward - do it completely cold, remove valve cover, orient to valve completely closed, then adjust.
/ B7100 Valve adjustment spec's? #2
Workshop manual says .006 to .008 inch for both with engine cold with piston at TDC on compression stroke.
thanks, got it done today. appreciate it! didn't get to fire it up as i'm waiting to seal the radiator.
Thorp Stainless Steel Feeder (A65640)
Thorp Stainless...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
