B7100 LED Flasher project
/ B7100 LED Flasher project #1
6mmbr
Indianapolis, IN
Hi. I was looking to kill some time so decided to change my hazard flashers to LED on my '94 B7100. Why? 'cause I like LEDs - no rational reason behind it. It was a cold winter day and I wanted to spend some money. I think I did it the hard way too. I subsequently found that you can buy some LED bulbs that will fit into the auto sockets and may be good. Oh, and I think the incandescent bulbs are brighter anyway. So with all those things going for it, here is what did:
Bought some LED marker lights from Meier:
and then cut them down into this shape to fit the lens:
I took the lamp apart:
and then reusing the mounting bolt with the hole in the middle (important part, don't let that one get away..) wired it all together:
and put it all back together:
It lights up ok, doesn't get hot, and sucks almost zero from the dynamo. Most importantly, I can tuck my thumbs under my armpits, rock back on my heels, and say "yup, did that".
thanks.
Oh, and don't forget to check out these other great B7100 threads:
JT Huskin's great thread:
http://www.tractorbynet.com/forums/...g/226940-b7100-restore-project-has-begun.html
B7100 modified dash thread:
http://www.tractorbynet.com/forums/...ng/233355-b7100-modified-instrument-dash.html
B7100 D750 engine stuff thread:
http://www.tractorbynet.com/forums/kubota-owning-operating/229050-d750-kubota-engine-what-part.html
B7100 HST neutral finder thread:
http://www.tractorbynet.com/forums/...-hydrostatic-transmission-neutral-finder.html
B7100 spinner knob thread:
http://www.tractorbynet.com/forums/showthread.php?p=2741035#post2741035
/ B7100 LED Flasher project #2
Nice conversion! I may be doing similar on our B5100.
/ B7100 LED Flasher project #3
Great work! My tractor does not have the tail light or flashers from the factory. The flasher switch location in the dash still had a factory grommet plug in it. I am curious to see if there are any motorcycle flashers [LED] on the market that I could make work on mine. My project is in slow mode right now. I just get a moment here an there to work on it. Will get some pictures soon.
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
ECONO SHELLER FOR PEA / BEAN (A63291)
ECONO SHELLER FOR...
2009 Toyota Highlander SUV (A61574)
2009 Toyota...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
