B7100 Front axle fill level
/ B7100 Front axle fill level #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I searched and could not find a specific answer, and I have the IT manual and it tells me the volume, but I would rather just check it.
I just bought my father a well used B7100 gear drive, 4wd tractor. I want to check the fluid levels in the front end (3pts) and I have pulled the fill plugs and nothing comes out nor is it visible. I would rather not have to drain and refill them all.
What level is "full"? Should I be able to see the gear oil through the fill plug hole? Is there a different level plug that I am missing or something?
Thanks for the help.
Alan Bechard
/ B7100 Front axle fill level #2
Best to drain them and then refill. It doesn't take long and is very easy.
When I do mine I fill till they are full which is quite a bit more than called for.
Egon
/ B7100 Front axle fill level #3
Hi
Front axle case oil = 0.7litre of oil
Left & Right axle gear case oil = 0.15litres in each
the above according to the operators manual,
hope this helps
Mat
/ B7100 Front axle fill level #4
Alan,
I have also tried to find an answer to this question but have been unsuccessful. I induced a leak in the front seal of my B2150 going down the road wide open in 3H, I forgot to take it out of 4WD. I had not had a leak until then. I have to top off occasionally. The owners manual doesn't give any direction on this. I just add to the bottom of the neck.
Which brings up the question: If overfilled will it cause the seal to leak at a faster rate? I'll let you know if I find out anything.
Sorry I had not responded back here. It is my dad's so figured as mentioned above, just do it, do it right, change it out and be done. .15 L is nowhere near the bottom of the fill plug, I would think overfilling it like that could potentially cause problems as well.
Fresh 80/90 in all three area's and it got rid of the noise it was making.
Thanks folks.
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40XXMJ464379 (A65563)
2021 Kenworth T880...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Planter Seed Plates (A65640)
Planter Seed...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
