B7100 fragile steering boxes
/ B7100 fragile steering boxes #1
chrisinnh
I learned something else from my recent hydraulics adventures:
One of the tractor salvage places I talked to said:
"B7100? Sure I've got at least a dozen of those... Wait, you're not looking for a steering gear box, are you? 'Cause those are all sold already. Hydraulic pump? No problem. Just make sure you take care of your steering box."
Apparently the B7100 (and I assume 6100 and 5100) have a fragile steering box?
It's the first I've heard of it, but if the salvage yard has sold every gearbox, then I guess It must be true.
I freshened the oil in mine.
/chris
/ B7100 fragile steering boxes #2
Kubota has parts to rebuild the steering box.
Mines been rebuilt once. They take a beating if you do a lot of loader work.:D
Kubota also have new steering boxes.:D
/ B7100 fragile steering boxes #3
if i remember it is like 600 for the complete box and 300 for the main gear that braeks inside thats y i did below and love it
/ B7100 fragile steering boxes #4
On mine the thrust bearings went out and the junk from the top one fell into the little worm gear assembly. I replaced the bearings but the damage was done. Ended up costing me close to $170 for a new shaft assembly (with the block full of bearings that rides the shaft).
When I opened it up it looked like no one had ever changed the fluid. The thrust bearings were about $6 each and you need two. If your steering wheel sticks, pops, or 'moves up' when you turn it go get the bearings.
Charles
/ B7100 fragile steering boxes #5
When I got my B7100 I noticed that there was no oil in the steering box. I filled it, now it leaks, so I ordered seals.
/ B7100 fragile steering boxes #6
My 6100 had the steering assy replaced before I purchased it. Glad I didn't write the check for it.
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
Mineral Feeder (A66408)
Mineral Feeder...
1997 International School Bus (A64194)
1997 International...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
