B6000E??
/ B6000E?? #1
Kiotimike
Ortonville Mi.
Kioti Dk40
I have a friend looking at a 2wd B6000E with FEL,Woods48"RFM,and a front mount snowblower.Also has wheel weights and chains.It is a 2cyl. diesel he doesn't know how many hours are on it.The seller wants $5500.00.The pictures I've seen looks to be a clean unit for the age.All info. or advice will be appreciated.
Mike
/ B6000E?? #2
The B6000 series are a tough tractor, if he bought it im sure he would see many years good use out of it yet. The tractor was made somewhere around 30 years ago, it has a 12.5HP twin cylinder deisel. Most if not all parts should still be availiable from a dealer.
The main problem is that the PTO is non standard, with a smaller shaft and 12 splines instead of 6. The engine rotates a different way to the standard hence the reversed PTO. PTO converter units were available but were discontinued as they were deemed too dangerous. Expect to pay around $400 if you can even find one to buy.
On the other hand despite this they are virtually indestructible, built to be much bigger than they are and make a great step up from a GT to a proper tractor.
Sorry I cannot help on the price much but if in a good condition personally it would already be sitting in my back garden.
/ B6000E?? #4
Mike,
I had a B6000 (FWD) and Mith is correct, it is one tough little machine. I am still kicking myself for getting rid of mine. $5500.00 seems to be a little on the high side, but if it is in good shape, in the long run I think it would still be a good investment.
Gary
/ B6000E??
Thanks Gary.The guy looking at the tractor is like most of us needs a reliable machine not a mechanical nightmare.I'm not sure if he has seen it action yet.He's just checking on $$$$ and can't afford to make a mistake.
Mike
/ B6000E?? #6
I know this thread is a little old but perhaps someone will still notice it. I recently acquired a property in S.FL. from an estate. The property came with a B6000E. In discussions with the neighbor, the tractor hasn't run in the 18 years since he's lived there but has no idea why--prior owner never got around to repairing so never discussed the probable cause. If it were a JD, AC or IH from the early 70's, there'd be no question whether to take the time/resources to get it running. However, a ~40 year old Kubota for some reason is leaving me more uncertain.
A 3PH mower is present but in pieces. Given the unique qualities of the PTO on the B6000E, I don't know that I'd be able to find any useable 3PH attachments for the tractor other than maybe a box-blade or roller or something that don't need PTO power. I have a ZTR to mow my grass so I'd probably just use the B6000E for pulling a wagon or possibly some grading (with blade).
The local Kubota dealer says the model is so old, parts will be scarce so they advise against putting much money into repairs. I have a pretty good respect for Kubota's as reliable basic workhorses but am not in a position to "want" to get caught in a money-pit. I'm no diesel mechanic so the repairs will need to be done by someone else. Would any of you throw a few $100 at diagnostics/repairs? Or, do you think better to sell it to someone who might actually get more use out of the rig?
/ B6000E?? #7
I'd sell it. You don't need it and a machine that has been sitting for 18 years needs more than you can give it.
/ B6000E?? #8
The biggest problem with that model is the counter rotating PTO shaft and finding implements that could be used on that tractor.
/ B6000E?? #9
My buddy has been restoring the b series kubotas for about 5 years now. I found a b6000 that I was going to buy and he turned me away from it bc everyone he has seen has has head or head gasket problems. He currently has three cracked heads in his shop for the baby 2 cyl and can't find anyone to repair them or can't find any new or used heads.
I've noticed searched craigslist and eBay that he might be on to something. There have been 5-6 with blown motors in the last 3-4 months that I have seen.... Not saying they are all junk by anymeans but it seems they do have some kind of issues
/ B6000E?? #10
Well, I think that gives me my answer. Thank you all for the assist. Since I've never seen a Kubota in the ad section of Antique power, I suppose I'll just go the Craig's List.
Chuck
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59910)
2020 FREIGHTLINER...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
24in excavator tooth bucket (A61307)
24in excavator...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2019 DRAGON ESP 150BBL ALUMINUM (A63569)
2019 DRAGON ESP...
