B5 Excavator
/ B5 Excavator #1
Operator4100
Lakeland, Fl.
ford 4000 1962
Hello to all, I hope you folks can help, My son has a Yanmar B5 excavator and the swing is weak,was wondering if anyone has one and what direction I need to go, I did a google search with little or no info, thanks, Dw
/ B5 Excavator #2
Several hours? Original owner? Abused or heavy usage over it's life? Check and clean the swing races (inner and outer) check, clean, and lubricate the swing bearings and pinion shaft. I have logged many hours on these small minimal tail swing/ zero tail swing excavators and they usually end up with a lot of wear and dirt in those areas. We have on occasion used them actually submerged in water and mud over the swing races and bearings. We had 1/2 inch soft laid winch cable wrapped around the races also. So check and re-check and clean. If no luck you may be in for new races, bearings, and pinion.
/ B5 Excavator
Thanks for the help I will look at the races though it swings fine on level ground but on side ground trying to swing uphill it's weak, i talked to a dealer today and he said I should have 2744 psi to the motor and I have only 1500, so I'm thinking maybe the pump is getting weak. Dw
/ B5 Excavator
The name I'll have to write it down and type it in tomorrow, actually it has two pumps on it a lare one in front of a smaller one, the large one appears to be a piston type while the other is a gear type, I got the gear type pulled today which I've found out is the swing pump. DW
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2005 STERLING LT9500 SERIES HYDROVAC (A67714)
2005 STERLING...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
