B414 rescue
/ B414 rescue
Question
As much as I am supposed to be working on the kitchen, my mind is off in the shop.....:)
I see a sale on some hydraulic cylinders. From what I can see on the web from images, I think the model number of my loader frame is B901. Does anyone know the specs on the cylinders for it? I cannot find it anywhere I have looked. The one I have is partially open but seized. It looks about 30 or 32" stroke and 1 3/4" shaft. I can get a good price on a 30" stroke x 1 1/2" shaft. Since I am changing to 2 way cylinders (double acting?) the shaft size may change. Also, from what I have seen in some newer Yanmar machines, their cylilnder shaft size is quite a bit smaller so I am thinking the ones on sale will do the job fine, providing I am not going to limit my lift too much with a 2" shorter stroke. Any input for me? Does anyone know what length the stroke would be on that cylinder?
The one I have found is this one
2-1/2 in. Bore x 30 in. Stroke Threaded Head Utility Cylinder | Princess Auto
/ B414 rescue
:confused: I am looking for the control valve now for the tractor. Considering that the original hydraulics had single acting cylinders, and I want to put double acting ones on, what parameters do I need to look for in a valve?
I see the terms "Power beyond", "Open Center", etc. If I understand correctly, I will be hooking into the quick connector already there (I assume it was for the original loader assembly, which is long gone) but then I need to hook in a return line somewhere....? I am thinking I need an Open center vavle but not sure about "Power beyond"....?
I have seen some valves on eBay
Hydraulic Directional Control Valve 2 Spool Tandem Center Spring Return 12 GPM | eBay
and am considering one of them but for a few bucks more, I can get a joystick version from Princess Auto....
http://www.princessauto.com/pal/en/...-Joystick-Directional-Control-Valve/8410763.p
which would you do or would you hold out for a Prince Valve? Princess Auto has them on sale occasionally and since I am still working on the kitchen, I have some time to make a decision.
Any advice available?
Shawn
iDrive TDS-2010H...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
