B3350 HP
/ B3350 HP #1
sarti
Central Illinois
Kubota L3901 BX2670
What is the correct HP on the B3350 some say 30 like the Kubota web site,, others are saying 33
Also have the new ones changed over to rail injection
thanks
/ B3350 HP
just saw where the LX is going to take the place of the B,,I guess I will wait and see what comes
/ B3350 HP
tractor data and a few other places selling tractors,,not really sure all the info on kubotas web site is a sure thing,,I will go talk to my dealer
/ B3350 HP #6
Absolutely wait. The B3350 has been a very problematic machine.
/ B3350 HP #7
thanks
According to the published specs in the Kubota sales brochure dated 06/16, which I have in my hand, Engine gross HP is 33.0 (SAE J1995) and PTO HP is 27.0.
I have been "told" that the HP rating of the forthcoming LX 3310 will be the same.
SDT
/ B3350 HP #8
Yes, the LX 3310 will replace the B3350 and is expected at the dealers in the spring.
The LX series will have a similar 4 cylinder engine with a common rail injection system and an emissions system similar to that used on other Kubota tractors that have been much less troublesome. There will be some other improvements/enhancements as well, e.g., drive in FEL with auto connect 4 hose hydraulic manifold, etc. You can also expect a price increase.
HP rating will remain the same as the 3350.
SDT
/ B3350 HP #9
I use tractordata specs only as starting points as there are many inaccuracies therein.
SDT
/ B3350 HP #10
Unless you put your tractor on a Dyno, isn't all written information about it speculation and possibly riddled with inaccuracies? Thus all things you read are simply a guide.
An example of this is the current emissions issues. The guides used to determine HP have softened. A slight blurring of accuracy is now acceptable. There is no enforceable regulatory guidance required. The manufacturers wiggle around in this soft goo all the time.
/ B3350 HP #11
I guess everyone is right. It all depends on what type of HP is being referenced.
From wholegoods listing 2016:
B3350HSD...................... B3350HSDC
SAE Gross HP: 33.0 ........ SAE Gross HP: 33.0
Engine Net HP: 29.6 ....... Engine Net HP: 29.6
PTO HP: 27.0 ................. PTO HP: 27.0
Ei Mdl V1505 ................. Ei Mdl V1505
Net and PTO are the only relevant numbers above in my opinion. Unless your willing to run your engine without water pump, fan or alternator. :D
/ B3350 HP #12
Well stated and proven. Much better than my rambling explanation above. :)
/ B3350 HP #13
And then there are tractors with actual test results by the Nebraska Tractor Test Lab. Sadly there are no test results for the B3350. Nebraska does not require testing tractors with 40 HP or less. (Unclear if this 40 HP limit is gross or net.)
/ B3350 HP #14
Note the SAE spec referenced above.
I would trust the manufacturer's published specs before I would trust any dealers dyno.
SDT
/ B3350 HP #15
thanks
any particular reason why 33hp or 29.6hp would make a difference in this tractor ? Just Curious as Im a new to Orange guy.
/ B3350 HP #16
SDT
And with all due respect, I'd be just the opposite. Manufacturers will state HP and not disclose that it's determined mathematically without any accessories. Is that honest?
/ B3350 HP #17
Because 29.6 is 90% of 33. If it's okay with you that the manufacturer's machine only produces 90% of it's claimed power, then it's okay with me.
/ B3350 HP #19
very constructive answer. thanks.
/ B3350 HP #20
Seems to me that it produces precisely what is claimed. 33 Gross HP is 33 gross HP, which is what is stated in the sales brochure. 27.0 PTO HP is 27.0 PTO HP, which is what is stated in the sales brochure.
I fail to see how anyone can interpret this to mean that the engine does not produce the HP, gross or PTO, that Kubota claims that it does.
SDT
2004 John Deere 4720 (A60462)
2004 John Deere...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
(2) UNUSED 380/85R30 TIRES W/10 LUG RIMS (A62130)
(2) UNUSED...
