B3350 HP
   / B3350 HP #11
I guess everyone is right. It all depends on what type of HP is being referenced.
From wholegoods listing 2016:
B3350HSD...................... B3350HSDC
SAE Gross HP: 33.0 ........ SAE Gross HP: 33.0
Engine Net HP: 29.6 ....... Engine Net HP: 29.6
PTO HP: 27.0 ................. PTO HP: 27.0
Ei Mdl V1505 ................. Ei Mdl V1505
Net and PTO are the only relevant numbers above in my opinion. Unless your willing to run your engine without water pump, fan or alternator. :D
   / B3350 HP #12
Well stated and proven. Much better than my rambling explanation above. :)
   / B3350 HP #13
And then there are tractors with actual test results by the Nebraska Tractor Test Lab. Sadly there are no test results for the B3350. Nebraska does not require testing tractors with 40 HP or less. (Unclear if this 40 HP limit is gross or net.)
   / B3350 HP #14
Unless you put your tractor on a Dyno, isn't all written information about it speculation and possibly riddled with inaccuracies? Thus all things you read are simply a guide.
An example of this is the current emissions issues. The guides used to determine HP have softened. A slight blurring of accuracy is now acceptable. There is no enforceable regulatory guidance required. The manufacturers wiggle around in this soft goo all the time.
Note the SAE spec referenced above.
I would trust the manufacturer's published specs before I would trust any dealers dyno.
SDT
   / B3350 HP #15
What is the correct HP on the B3350 some say 30 like the Kubota web site,, others are saying 33
Also have the new ones changed over to rail injection
thanks
any particular reason why 33hp or 29.6hp would make a difference in this tractor ? Just Curious as Im a new to Orange guy.
   / B3350 HP #16
SDT
And with all due respect, I'd be just the opposite. Manufacturers will state HP and not disclose that it's determined mathematically without any accessories. Is that honest?
   / B3350 HP #17
Because 29.6 is 90% of 33. If it's okay with you that the manufacturer's machine only produces 90% of it's claimed power, then it's okay with me.
   / B3350 HP #18
Ahh for the days of the Bosch A and P inline injection pumps. Horsepower was as far away as your 10mm wrench and screwdriver.
   / B3350 HP #19
very constructive answer. thanks.
   / B3350 HP #20
Seems to me that it produces precisely what is claimed. 33 Gross HP is 33 gross HP, which is what is stated in the sales brochure. 27.0 PTO HP is 27.0 PTO HP, which is what is stated in the sales brochure.
I fail to see how anyone can interpret this to mean that the engine does not produce the HP, gross or PTO, that Kubota claims that it does.
SDT
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
202475 (A54757)
202475 (A54757)
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
