B3350 HP
   / B3350 HP #1
sarti
Central Illinois
Kubota L3901 BX2670
What is the correct HP on the B3350 some say 30 like the Kubota web site,, others are saying 33
Also have the new ones changed over to rail injection
thanks
   / B3350 HP
just saw where the LX is going to take the place of the B,,I guess I will wait and see what comes
   / B3350 HP
tractor data and a few other places selling tractors,,not really sure all the info on kubotas web site is a sure thing,,I will go talk to my dealer
   / B3350 HP #6
Absolutely wait. The B3350 has been a very problematic machine.
   / B3350 HP #7
thanks
According to the published specs in the Kubota sales brochure dated 06/16, which I have in my hand, Engine gross HP is 33.0 (SAE J1995) and PTO HP is 27.0.
I have been "told" that the HP rating of the forthcoming LX 3310 will be the same.
SDT
   / B3350 HP #8
Yes, the LX 3310 will replace the B3350 and is expected at the dealers in the spring.
The LX series will have a similar 4 cylinder engine with a common rail injection system and an emissions system similar to that used on other Kubota tractors that have been much less troublesome. There will be some other improvements/enhancements as well, e.g., drive in FEL with auto connect 4 hose hydraulic manifold, etc. You can also expect a price increase.
HP rating will remain the same as the 3350.
SDT
   / B3350 HP #9
I use tractordata specs only as starting points as there are many inaccuracies therein.
SDT
   / B3350 HP #10
Unless you put your tractor on a Dyno, isn't all written information about it speculation and possibly riddled with inaccuracies? Thus all things you read are simply a guide.
An example of this is the current emissions issues. The guides used to determine HP have softened. A slight blurring of accuracy is now acceptable. There is no enforceable regulatory guidance required. The manufacturers wiggle around in this soft goo all the time.
30KW GENERATOR (A58214)
30KW GENERATOR...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2019 International HX620 T/A Day Cab Truck Tractor (A55973)
2019 International...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
