It's just a push in plug. I use a pair of slip joint pliers to get a better grip on it, then twist as I pull up.
Joe
Got a chance to try last night. Had to eventually get a screwdriver under it and pry it out. Once out I found that some fine sand was around the plug making it stick. Cleaned it off with a bit of 600 grit and put petroleum jelly on it. Still a good fit but can remove it by hand now. Thanks for the reply.
I've heard that petroleum jelly can have a bad affect on rubber components. I would use plumber's grease. It used on O-rings and similar type components for a better seal in plumbing. And if it's safe for drinking water, you know it's non-toxic.
I have been using it for decades and never had a problem.
