B3200 Seat Belt
   / B3200 Seat Belt #1
ruralruss
NW Georgia
Kubota B3200
Does anybody know of a non spooling seatbelt retrofit? The stock one is totally unusable for typical applications.
Russ
   / B3200 Seat Belt
* Why is that?
What do you mean?
It continually tightens until you are pinned down with the seat spring compressed. It might work if you are moving on a perfectly smooth surface and don't turn to look behind you or shift your weight. Problem is I can't do any work that way. I just need an old fashion seat belt that I can adjust to fit around me and keep me from getting thrown off. For now, I just can't use it.
Russ
   / B3200 Seat Belt #4
Not a bad request actually. The old style with the fixed length latch side and the manually adjustable lap belt had its advantages.
   / B3200 Seat Belt #5
Russ
I believe that's a bit extreme, well I believe it's way extreme. I agree that it's an issue but "totally unusable for typical application"??? I do hillside work and when going downhill then back up all of my tractors have tightened to the extent that I have to undo the seatbelt every so often which is a bit aggravating and then reconnect it. On level ground or on slight ups and down which I think are most typical applications it doesn't cause any problem. But I agree that I would rather have a plain ole me tightening hook up because of my steep hill side.
   / B3200 Seat Belt #6
A center seat belt from an auto salvage yard should fill the bill. These were used extensively in the 70s and 80s. I paid $3 each for a pair I put in a go-kart some years ago.
   / B3200 Seat Belt
I don't have any ground that is flat or smooth. I would like to use it but the discomfort and movement restriction it causes makes it impractical on my property.
This is coming from a guy that religiously straps in.
Russ
   / B3200 Seat Belt
I may give that a try.
Russ
   / B3200 Seat Belt #9
Instead of replacing the OE belt, is there some way to prevent it from retracting. I know my wife does not like the shoulder strap in the car rubbing on her neck all the time so she simply put a clothes pin on the belt to keep it from going in any further. (Please no lectures from the safety police here. Believe me, I have tried) I realize a clothes pin would probably not work on the tractor, but there must be something you could clamp on the belt to prevent it from retracting. Maybe a zip tie?
   / B3200 Seat Belt
That is a good idea as well. I never considered such a simple fix! My wife drives the tractor from time to time so that may be an issue. I may try it until I can maybe find a center belt.
Russ
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
6"x8' Treated...
