B3030 vs. B3300SU
/ B3030 vs. B3300SU
Although bigger always seems better when it comes to tractors, I doubt that I could afford an L-series with 30 hp or more (in good shape).
/ B3030 vs. B3300SU #12
Not bigger; HEAVIER.
What is available in the used market, and used pricing, is mostly ordered by random.
There are couple Ls and a couple Bs for sale on eBay, near Zip Code 15301, right now:
LINK: Tractors | eBay
Here are some SOLD listings: Tractors | eBay
There are a number of (orphan) Ford tractors listed pretty cheap. There are numerous Ford tractor fans active here. Here is where you can determine Ford tractor weights and details: TractorData.com - information on all makes and models of tractors
/ B3030 vs. B3300SU
The B3300SU owner says he bought the unit brand new from a dealer. It didn't come with a FEL.
/ B3030 vs. B3300SU #15
I own a B3030 cabbed model. First thing that I would advise you is to stay away from the tractors with the new emissions if you can. However, having said that, I agree with an earlier poster. If you have 10 acres, I believe you should consider going with an L series. You will never ask to have less power with a tractor--only more. I'm also assuming that you get some big snow in your area. A heavier tractor will make shorter work of its removal. Whatever you buy, see if you can get a set of rear chains thrown in. And if you opt to get the rear tires loaded, I recommend foam in my opinion. It's more expensive and maybe a rougher ride, however, you will be able to drive over nails and never worry about getting a flat.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
1607 (A57192)
1607 (A57192)
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2019 Deere 35G (A53317)
2019 Deere 35G...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
