B3030 vs. B3200
/ B3030 vs. B3200 #1
archerynut
Platinum Member
Near Pittsburgh, PA
Looking again
Allright everyone,
I have decided that it is a moral imperative to upgrade to a new tractor. Therefore I am stuck between the two, any thoughts are appreciated, and ideas on price are accepted also. PM if you want to be kept anonymous. Both fit the roll of what I want it to do, and the cab really isn't an option for me. Looking for TLB plus MMM.
/ B3030 vs. B3200 #2
Allright everyone,
About the only meaningful difference is one is the Luxury model at quite a bit more cost. If you want to pay for the extra features then do so. If you don't want to pay the extra money for the extra features then don't. The Kubota build site will tell you the difference in features and price between the two machines. I've had a B3200 and it was one of the finest Kubotas I've owned which shows I was not willing to pay the extra for the B3030. Others on this forum have paid the extra and most have not. Sure the B3030 buyers will tell you they are glad they did and maybe a few B3200 buyers will say they wished they had payed the extra for the extra luxury features. Your choice from here. Good luck and pull the trigger.
/ B3030 vs. B3200 #3
Allright everyone,
I chose the B3200 over the 3030 mostly because of cost but I also wanted as much hp as I could get in the same size package. The 3030 has some nice features but only you can decide if that means: enough to pay the extra $$$$.:thumbsup:
/ B3030 vs. B3200 #5
The two tractors are virtually identical in abilities. I'll try to explain some of the differences.
The 3030 has alot of deluxe features. Some of these are:
position control vs. quarter inching on the 3200
extendable three point hitch arms / telescoping sway links vs. basic arms / turnbuckles on the 3200
tilt wheel vs. non
hydrostatic steering vs. steering box / power assist on 3200
arm rests vs. none
hydraulic PTO engagement vs. clutch pedal / manual engagement on 3200
no clutch pedal vs. clutch on 3200
I'm sure I'm forgetting a few features.
IMO the two big ones are the position control and the deluxe three point hitch. If I owned the 3200 I'd have no choice but to add the 3030 style 3 point assembly.
Two things I like better on the 3200 are:
If you go with the Kubota backhoe, its more integrated and makes for a more compact package. The operators seat turns around instead of having two seats. Since its more compact, its more maneuverable in tight areas.
I like the under-seat hydraulic valve better, keeping the loader control in a comfortable position at your right hip. This can be remedied on the 3030 by ordering it with the cab style joystick, as several members here have done. If ordered that way, the price difference is minimal.
Just some food for thought......... the new B3000 is due out within a few months. It is the updated 3030. No doubt the backhoe will be integrated like the 3200 as well as the seat-side loader control..... probably with a little swoopier bodywork. Maybe you'll want to wait for the B3000? Maybe not......
/ B3030 vs. B3200 #6
tilt wheel vs. non
arm rests vs. none
I will NEVER buy a tractor without position control again if it is available in the size tractor I need.
/ B3030 vs. B3200 #7
Price on my B3030 from February 2009:
B3030 HSDCC deluxe cold weather cab (heat, A/C, front & rear wipers/washers) - $20,100
LA403 loader - $4700
Those prices do not include NY state sales tax of 7.75% in my county. Those prices are also before factoring in my trade.
/ B3030 vs. B3200 #8
A lot of the improvements on the 3030 you will not notice unless you are going to put a lot of hours on then you will see that the 3030 will be less troublesome as it ages. But that of course is 20 years down the road.:D
One item that swayed me to the 3200 was the loader valve. The integrated valve by your right leg on the 3200 is far superior to the loader mount valve and the cab version for the 3030 I did not like because of the cable run valve. JMO
/ B3030 vs. B3200 #9
A lot of the improvements on the 3030 you will not notice unless you are going to put a lot of hours on then you will see that the 3030 will be less troublesome as it ages. But that of course is 20 years down the road.:DJMO
How do you figure the B3030 will be less troublesome as it ages? Mechanically it is almost identical to the B3200.
As to the original question, I chose the B3200 due to the lower cost and the newer designed loader/loader valve. The backhoe option also looked better if I ever wanted to add one someday. The only feature I wish I had was the better 3pt stabilizer bars (which is an easy upgrade.) The extendable lower links are nice on big tractors, but the implements for these little tractors are so small you can pretty well move them into position by hand. Quarter inching valve doesn't bother me (actually has some advantages in ceartain circumstances) and the transmission driven PTO works fine since it's on a HST tractor.
Someone mentioned the greater power of the B3200 being an advantage, well, it's only got more power on paper. The engines are identical and put out the same torque, same HP, they just rate the B3200 at a little higher rpm to make it look better.
/ B3030 vs. B3200 #10
Hydrostatic steering is more durable
b3030 does not have a clutch
just a couple items I can think of at the moment.
/ B3030 vs. B3200 #11
Those are pretty nit picky things, I just don't see either of those being an issue. Kubota has used the power over manual steering for a long time and I've seen very few with trouble. As for the clutch, I can't see it ever wearing out since it's only used to engage the PTO. Those systems have been in the B-series lineup a lot longer than the deluxe features, if reliability had been a problem Kubota would have moved away from it by now.
/ B3030 vs. B3200 #12
Yep your right, it is nit picky. I was just throwing out a few things that after hard use might wear sooner. As you can see from my list what I bought. I considered that I will be 150 years old before I wear mine out. Some people use their machines allot harder than I
/ B3030 vs. B3200
OK, update in order I suppose.
Stopped by the local dealership and they have a "demo" b3200 for sale. Heres the deal they gave me 52 hours on B3200, very slightly used BH75 (10 hours if that), 60" mower, filled rears, tooth bar, PTO generator (15 KW), clamp on 72" dozer blade (plow), $28200. Any thoughts? I haven't got a hard figure for the trade in of my GC 2310 from them yet.
My first thoughts are I would prefer the new BH 77 with a rotating seat but for how much I use the BH it doesn't matter. I have concerns with a demo, it looks great but if someone else didn't like it? Eye of the beholder? Didn't start anything due to time constraints, but now worried about excessive vibration in the B3200.
/ B3030 vs. B3200 #14
I'd try to locate the previous owner if possible. That tractor came back for a reason.
Whether it was an operational or a financial issue is what I'd be looking to find out. Maybe someone had problems with the tractor, maybe they simply had trouble affording the payments.
/ B3030 vs. B3200 #15
If it's sold as a demo, and not used then it's 'as new' and never been sold before. It should have a full factory warranty from the day you purchase it. I wouldn't be concerned about the hours. I tried to buy a demo 3030 from my local dealer a couple years ago....... it had almost two hundred hours on it. It was a tractor they used to bring to all the country fairs to display for two seasons. Warranty was the same as if it had zero hours.
/ B3030 vs. B3200 #16
I had a B3200 with under 50 hours and decided I'd rather have a F3080 soooooooo out went the B3200 with no issues or problem and in came the new F3080 6' mowing deck and also out went the BX2660 with 50 hours and no problems or issues and in came the BX25. If it was previously owned then call the former owner. If they say it was me, then you don't have to call.:laughing:
/ B3030 vs. B3200 #17
That sounds like a very good deal. Course that is based on everything having having a "new" warranty. If those hrs are accurate it's barely broke in and was probably used as a loaner/lot demo. definitely put it through it's paces when/if you test it out.
re. 3200 vibration. Theres a long thread over in the Kubota owner/operator section concerning the vibration issue in the 4 cyl diesel in the B3030/B3200 series and one fellow has indicated that a timing change (retarded some) has not only corrected the vibration issue but made cold starting and running 100% better. You may want to check that thread out. And also mention this to the dealer before you buy.
re. BH swivel seat. seeing as how you have a GC2310, isn't that the model w/an OEM BH and swivel seat? If so I can see why you would like that setup but IMHO, I consider it an unecessary step (major PITA :D ) to have to dismount and continually swing the seat around for major repositioning of my BX23. I much prefer just having to dismount and remount 2 seats over that. But then again thats a personal preference :D
I know the larger Cases and JD industrial TLB's have ample room to just stay seated and just swing the seat fore & aft but unfortunately theres no room on our SCUT's and CUT's for such ease of operation :D
Good luck
Dave
/ B3030 vs. B3200 #18
I just bought a B3200. I sold my B7800 and before that one i had a B7500. All great machines only had one minor problem with By B7800 and B7500 and that was moisture in the control valve that would freeze in the winter. The new B3200 with Kubota BH, is awesome, everyone talks about the vibration, I don't notice it. The only minor problem I have is the new design of the front loader it doesnt have the cross bar that went over the machine to keep the loader arms together and when the weigt is taken off the loader pins they rattle really bad, but as far as performance and duribility the machine is awesome.
/ B3030 vs. B3200 #19
Gee that demo B3200 with 50 hours and is a Deal wow! I have a B3200 TLB and think it's great, can't say anything about the 3030 as I have not owned one.
DevilDog
/ B3030 vs. B3200 #20
Had a B7800 for 3 years and I HATED that bar across the fuel filler cap as did several other B7800 owners on another tractor forum that I used to visit. Glad the L3240HST and B3200 didn't have it.
1 PALLET OF JACK & MISC TRUCK PARTS (A66091)
1 PALLET OF JACK &...
2012 DRAGON 130BBL VAC TRAILER (A67714)
2012 DRAGON 130BBL...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
213324 (A64279)
213324 (A64279)
PORTA POTTY (A67714)
2018 International WorkStar 7500 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A66736)
2018 International...
