B3030 Rear Tire Pressure
   / B3030 Rear Tire Pressure #1
Kubota 2007
PA
Kubota L4740,B3030,ZD326, RTV 900,L4200 1120RTV
B3030 with R-4 Loaded with windsheild Wash I was told to put so much air in, but I forgot, I checked and I have 9lbs in each when the valve stem is at 12:00, Tires seem to be squating so I put it up to 15 psi with back hoe installed. Any idea what the pressure should be?
   / B3030 Rear Tire Pressure #2
Funny thing about tractor tires. Due to the many different applications, you will rarely find a list of tire pressures. You are on the right track. Adjust your pressure so that your tires look right and perform properly. When you remove your backhoe, you may want to reduce the pressure.
   / B3030 Rear Tire Pressure #3
They should be flat across the tread surface when properly inflated. probably about the original amount.
   / B3030 Rear Tire Pressure #4
I run my B3200 loaded rears at 14. No backhoe but I usually have the box scrape on.
   / B3030 Rear Tire Pressure #5
My owners manual for a B2910 shows R-4 tires should be inflated to 20 psi with or without ballast.
   / B3030 Rear Tire Pressure #6
I have the turf tires on my B3030 loaded with Rimguard. The sidewall of my tires say 35psi. I notice if I run much less than that, the tractor gets squirrely and less stable side to side.
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
