B3030 Rear tire chains
   / B3030 Rear tire chains #1
Kubota 2007
PA
Kubota L4740,B3030,ZD326, RTV900,L4200 1120RTV,L4310 & KXO4-5.JD 310SG,310J,JLG 450AJ. 0-5
I have a B3030 and I知 considering putting tire chains on it, has anyone successfully put rear chains on R4 tires, does it need wheel spacers, if so what size, what type of chain are you using? I値l be on black top all the time.
   / B3030 Rear tire chains #2
I have both F & R chains for my B3350, which is similar.
I have R4 tires and my chains are two-link ladder style. Rear wheel spacers are mandatory due to inadequate fender clearance. I have Kubota 1 3/8" rear spacers.
Twist-link ladder chains are not damaging to asphalt given common sense.
Not sure about the B3030 but the B3350 is offered with optional, oversized tires which are not compatible with tire chains, spacers or otherwise.
SDT
   / B3030 Rear tire chains #3
They also offer,or did offer,rear fender extensions.
Might be nice if running wheel spacers.
Good Luck!
   / B3030 Rear tire chains #4
I found an ex-Kubota dealer selling stuff out of his barn, and got some 11/2' Kubota spacers and some ladder chains, which required modificatons but then worked fine with my L3400 with turf tires. The spacers help with stability, as well. Unless they are too small, chains can be shortened and otherwise modified to fit. Connecting links are not hardened, typically.
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
202480 (A54757)
202480 (A54757)
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
