Price Check B3030 Pricing
/ B3030 Pricing #1
Erniel29
Ok, I decided not to go with the BX2230 and go with something a bit bigger. So I am opting for the B3030. My loacal dealer in Ocala has quoted me $21,400 for the 3030 with 6' MMM and a FEL.
Thanks
Ernie
/ B3030 Pricing #3
i think everyone will agree that pricing is regional. i got b3030, la403, 72" mmm, and ballast box for 19425.00. i like it fine so far......... /forums/images/graemlins/grin.gif
/ B3030 Pricing
Where are you located??
Ernie
/ B3030 Pricing #6
I am in Michigan and paid $20K including 6% sales tax for B3030, FEL, 60" MMM and 5' Land Pride rear blade.
/ B3030 Pricing #7
I am in Michigan as well and paid about 20,500 with tax for a 3030, FEL, and 72"MMM.
/ B3030 Pricing #8
I paid 19500.oo for the b3030,fel, 6ft 3pt mower and 5ft box blade in Kansas.
/ B3030 Pricing #9
I paid $29,700 back in August for 3030, R4s, FEL, BH, 6ft Curtis Power Angle Plow, 2 rear remotes, 6 inch Chipper, filters and oil for 50 hr service. Can't wait for the snow /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ B3030 Pricing #10
I paid $28900. for B3030 W/ factory cab, am,fm,wb,cd, 403 fel, 2782 front snowblower, turf tires (rears filled)
/ B3030 Pricing #11
ernie,
When I was doing my pricing, the Ocala guy was the highest dealer I checked. Give Coastal Equipment Systems in Jax or McClenny Tractor sales a shout. They both were much less than the Ocala dealer for an L3130 gear with Fel. My quote from the Dealer in Jax was 17,430 for the afformentioned tractor. If I remember right, the Ocala guy wanted over 20K.
/ B3030 Pricing #12
how is that snow blower? they are pricey but the rear blade i have is not that effective on my 3030. i think the machine is light for pulling any significant amount of snow.
/ B3030 Pricing #13
I have yet to use the snowblower, kubotaone has the same rig as i, he had a small drive chain issue but he reports the machine is now working very well. As far as weight, my machine all tolled, cab, loader subframe,blower,etc weighs in at approximately 3700 lbs, i wouldn't call that real light?
/ B3030 Pricing #14
yeah yours weighs more than mine. my 3030 is around 2k lbs and then with the rear blade maybe 2300. the rears are filled but like tonight with the 7 inches of wet snow we got here just east of flint, mi my 3030 would not pull the snow. i had to flop the blade backward and get the ole neck kink method going. i did throw the loader back on to save time and give me more weight. i was curious you mentioned the loader subframe in your post, is that a seperate subframe than the one for your snow blower? i ask because when i priced a snow blower they wanted 4k and 900 of that was for a seperate subframe that will work the front blade, front broom, or snow blower. the blade was about 1200 and the blower about 3100 around here in mi, then add the 900. we have about a 15inch base here in lapeer and that is not common for us this early in the year. this year i could use that blower. have fun with it.
/ B3030 Pricing #15
The subframe for the loader consists of the two upright stanchions the loader itself locks into & the steele plating that attaches the uprights to the frame, approximately 400 lbs. The snowblower subframe is a seperate deal, it mounts up under the engine & front plate, i think it weighs in around 450 lbs.
/ B3030 Pricing #16
When I lived about 7 miles south of Fremont over in Newaygo County (50 miles north of Grand Rapids, more or less), I used an old 8N and back blade to move the snow out of the way. I only had to back it when I wanted to push the snow to the side of the road after I dragged it out of the driveway. It puzzles me that your 3030 won't handle your snow as well as the 8N did. More power, more or less the same weight, maybe the 8n is lighter, and 4wd. How much snow do you get, anyways?
Over there, people used to plow their whole yard clear so they didn't run out of places to put the stuff before they ran out of winter.
/ B3030 Pricing #17
hey teach,
we only occasionally get as much snow as we have now. i have about 15 inches in my yard, that is a lot especially for this time of year. the stuff that fell yesterday about 7-8 inches was wet, thus very heavy. i think the problem i was having is #1: gravel driveway #2: already 1-2 ft banks from the other snow, #3: long driveway
i used my dad's unit as well, it is not any better. he has a MF 1428V with turf tires. it has a wider stance and weighs about 500 more lbs. i think most of the issue is trying to push out the banks while pulling the snow and having to drive through the bank at the same time. in reverse i can go crazy, but i dont like neck kinks. - merry xmas
/ B3030 Pricing #18
The problem with the banks is why the people over by Fremont push it clear across the yard early in the season.
From working with my little Cadet, if you hit the bank at an angle while backing, you'll move it and open a hole for more snow. You don't need to crane your neck too much if there's nothing to hit besides snow. Just make a lot of shallow hits next to each other, sort of like half a herringbone pattern and you should be in pretty good shape. Just don't pile it to windward or you'll be making your own snow fence and it'll drift shut real quickly. /forums/images/graemlins/shocked.gif
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
