B3030 PITA
   / B3030 PITA #11
Going back aways. It was recommended that a heavy duty top link bracket be installed when using heavy rear attachments. do not know if it is available for the B3030. I bought mine because of the heavy rear blade I have. It also comes with the BL4690 backhoe.
You brackets sounds like the original 2 piece that came on my B2910. The heavy duty bracket is one piece and has more bolts holding it on.
   / B3030 PITA
I dont have any REALLY heavy impliments ( for a tractor to lift) but I have already bought heavier top links. I bent the rod end of the factory top link and called Kubota to see what they wanted for a new toplink...because I was told..by them..that the rod end COULDNT be unscrewed and replaced (??????) Kubota wanted $220 for a new toplink....:eek::eek::eek:
I went to TSC and bought a "China's Best" of the same length and much heavier for $19.95 and with the help of my farmer buddy got the factory link unscrewed and straightened and back into service.
( I should have realized that Kubota was going to give me a royal screwing on each and every part..but it didnt sink in until I had to pay $150 to replace a HEADLIGHT COVER!!!!!!:eek: ) which was the LAST Kubota item I'll ever buy!
Many many toplinks in the stable now and that way I can leave them on each impliment and dont have to keep re-adjusting them when I change impliments
The bracket on the tractor is more than heavy enough built though
   / B3030 PITA #13
I found a OEM top link on ebay. $20 including shipping.:cool: Looks better than original one.
I have 2 china top links. Plus a hydraulic top link. I only use the hydraulic top link on attachments that require adjustment while using them.
   / B3030 PITA #14
Try a 20" hunk of heavy chain.....much cheaper and it won't bend!
FWIW.......
Swmpbgy1
   / B3030 PITA
FWIW.......
Swmpbgy1
Kinda tough to adjust the attack angle on a back blade or a landscape rake with a chain?? I havent figured out yet how to PUSH a chain??
   / B3030 PITA #16
Sorry for the post.....your original post didn't really say what you were doing with the 3pt......just assumed for brush hogging......saw your implements in your sig.
Swmpbgy1
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
