B3030 or L2800HST
/ B3030 or L2800HST #1
cajordan
Which tractor would you buy if you could buy them for essentially the same price? Use will be for finish mowing, landscaping, loader use, etc on 3 acres? Will be rear mounted mower. I'm assuming the 2800 is a heavier duty tractor overall. Thanks in advance for the responses.
/ B3030 or L2800HST #2
If I was finish mowing any reasonable sized property the B3030 with a MMM would be my choice.
I have a L3400HST - same tractor as the L2800 with some more ponies. I would have considered the B3030 very seriously if I was finish mowing at all.
/ B3030 or L2800HST #3
The B3030 is around a 1000 lbs lighter than an L series. Better for ground engaging work, but not good on your lawn. I had a similar choice and chose the B3030HSDC over the L series for just that reason.
/ B3030 or L2800HST #4
With the exception of the mowing work ( I have a nice "grass cutter" besides) those are the exact same reasons I bought a B3030. And for MY uses..I went with the industrial tires and find that when I "get in over my head" I'll spin the tires before I can get close to breaking anything on the tractor itself. Works out good for a "tractor newbie"... /forums/images/graemlins/grin.gif
/ B3030 or L2800HST #5
I have used b2150and current b2910 both with 60 inch belly mowers for a total of 16 years on 8 acres. Four acres lawn and four field. Does great job on lawn and with the 30 hp I was able to sell my bush hog and do the field with the belly mower. I also have a FEL with 60 inch bucket that I take on and off in less than 5 min. My next move will be to the b3030 to replace the b2910. Good luck.
/ B3030 or L2800HST #6
I went through a similar exercise for 10 acres and bought the B3030. I don't regret it for a second. Not only is the B3030 lighter for mowing, it's got a tighter turning radius. The L2800 was more tractor than I needed and I really like the up-market features on the B3030.
/ B3030 or L2800HST #7
I thought the L2800 was only available in gear or shuttle shift?
/ B3030 or L2800HST #8
</font><font color="blue" class="small">( I thought the L2800 was only available in gear or shuttle shift? )</font>
It's offered in HST also...I have one with 110hrs on it.
/ B3030 or L2800HST #9
No shuttle shift transmission available. The 8x4 or HST are the only ones offered. You have to go to the L30 series to get a 8x8 shuttle shift.
/ B3030 or L2800HST #10
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
2006 Ford E-350 Passenger Van (A64194)
2006 Ford E-350...
