smfcpacfp
Veteran Member
- Joined
- Nov 21, 2007
- Messages
- 1,346
- Tractor
- Kubota B3030HSDC
There is a big cross member right below the oil drain plugs (great design). At first I thought I would take it off, but it is torqued seriously tightly. Then I figured I would raise the front of the tractor off the ground a bit and just let the oil drain down on the cross member and to the back since the tractor is now slightly tipped back.
Is that how it should be done?
