B3030 - not enough rpms - throttle adjustment?
   / B3030 - not enough rpms - throttle adjustment? #1
cart99
Northern VA
Kubota B3030
Recently I've been having throttle position issues. With the throttle lever at maximum position, I am barely in "PTO range", and what's worse is that as I run it, it creeps back to a lower RPM.
Do I need to tighten the cable or is there some other way to adjust both the "stop" position and the lever tension?
Any help would be appreciated.
Thanks!
   / B3030 - not enough rpms - throttle adjustment? #2
Try changing the fuel filter first.
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
Non running toro mower (A48082)
Non running toro...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2008 SHOP BUILT  STEEL TANKER TRAILER (A50854)
2008 SHOP BUILT...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
