B3030 - not enough rpms - throttle adjustment?
   / B3030 - not enough rpms - throttle adjustment? #1
cart99
Northern VA
Kubota B3030
Recently I've been having throttle position issues. With the throttle lever at maximum position, I am barely in "PTO range", and what's worse is that as I run it, it creeps back to a lower RPM.
Do I need to tighten the cable or is there some other way to adjust both the "stop" position and the lever tension?
Any help would be appreciated.
Thanks!
   / B3030 - not enough rpms - throttle adjustment? #2
Try changing the fuel filter first.
2019 Ford F-450 4x4 Crew Cab Gooseneck Flatbed Truck (A49461)
2019 Ford F-450...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
