b3030 hydraulics
/ b3030 hydraulics #1
Tombird
Kubota b3030
Hi , I have a b3030 with cab that had no hydraulic provisions for operating front end equipment. I bought the b2325 hydraulic kit , having trouble figuring out how to mount the unit to the tractor. I have the joy stick mounted in the cab , but the main unit is giving me mounting problems. Not sure if I have the right brackets , can't find much info online about it. I'm sure I'm not the first person to run into this problem , looks fairly easy to do once it's mounted. thank you
/ b3030 hydraulics #2
I assume you are talking about mounting the third function hydraulic valve! I have a B3000 and I mounted mine on the inside of the FEL arm with the quick disconnect mounted on the cross bar for the FEL.
/ b3030 hydraulics
I'm mounting the kit right beside the fuel tank and directly in front of the cab window. It looks very similar to yours that I can see in the first picture. My tractor didn't come with it from the factory , so I bought the kit . Doesn't seem like I have the right brackets for that location. Thanks
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
Pittsburg 4 row cultivator (A64119)
Pittsburg 4 row...
DINGO TREE SPADE (A61572)
DINGO TREE SPADE...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Location Tampa, FL (A61567)
Location Tampa, FL...
