b3030 hydraulics
/ b3030 hydraulics #1
Tombird
Kubota b3030
Hi , I have a b3030 with cab that had no hydraulic provisions for operating front end equipment. I bought the b2325 hydraulic kit , having trouble figuring out how to mount the unit to the tractor. I have the joy stick mounted in the cab , but the main unit is giving me mounting problems. Not sure if I have the right brackets , can't find much info online about it. I'm sure I'm not the first person to run into this problem , looks fairly easy to do once it's mounted. thank you
/ b3030 hydraulics #2
I assume you are talking about mounting the third function hydraulic valve! I have a B3000 and I mounted mine on the inside of the FEL arm with the quick disconnect mounted on the cross bar for the FEL.
/ b3030 hydraulics
I'm mounting the kit right beside the fuel tank and directly in front of the cab window. It looks very similar to yours that I can see in the first picture. My tractor didn't come with it from the factory , so I bought the kit . Doesn't seem like I have the right brackets for that location. Thanks
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
2 PALLETS OF SNOW CHAINS (A66091)
2 PALLETS OF SNOW...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
