B3030 HSDC AM/FM/CD player installation
   / B3030 HSDC AM/FM/CD player installation #1
MartinT
Jamul, CA USA
Possibly a NH TC33DA
I'm wondering if anyone knows where the cd player power plug is located in the B3030 HSDC cab. I've found it on the Kubota cab electrical schematic, and I've gathered all my parts for the installation; mini spade connectors, wire, speakers, etc, but was wondering if anyone can tell me where the power plug is. I can guess that it may be in the right forward corner under the headliner (forward of the blower motor bump) because I can see the antenna cable in that location. Just thought I'd ask before I drop the headliner and screw something up. Thanks in advance for any info...
Marty
PS - If anyone also knows where the speaker leads come out that would be a help too, but not as important because I can run those just about anywhere...
   / B3030 HSDC AM/FM/CD player installation #2
Martin T-
Could you get me an electronic copy of the B3030 cab schematic, maybe email it to me. I would appreciate it if you could, I would like to put a radio in my cab also, but have no idea where any of the wiring is. I don't know where the mounts for the radio are either if you can help me with that. Thank you much!
-Trav
Trav, I sent you an email saying I have the schematic scanned, but I never heard back. Drop me an email and I will forward the cab schematic to you.
   / B3030 HSDC AM/FM/CD player installation #4
MartinT, I'm not familar with the B series cab but I put a radio/cd player in my L series and all the wiring was right behind the radio blank where the antenna cable was located. There was one prewired plug that was for power, speakers and all. Hope that helps.
Ron
   / B3030 HSDC AM/FM/CD player installation #5
How do you get the headliner off to work on the wiring and placement of the radio bracket. I can see a few screws, but mostly some plastic type rivits seem to hold the panel in place. And is there somewhere to bolt on the radio bracket without drilling holes?
   / B3030 HSDC AM/FM/CD player installation #6
Martin - I never got your email, but I dropped you one tonight. Let me know if you got it. - Thanks!
   / B3030 HSDC AM/FM/CD player installation #7
I wasn't around when the guy put the speaker kit in my L series but he did it at my house and I believe that he removed the top of the cab to get everything. The headliner stays put. Maybe the B series works the same way.
   / B3030 HSDC AM/FM/CD player installation #8
I spent some time at the dealership yesterday regarding the radio installation on the B series. They reccommend the installation kit at a mimimum because it has the installation bracket. They couldn't tell me where it mounted or how to get at the wires, which they assure are above the liner. I inquired if they could get me some directions as to how and where the radio goes, they're going to see if the factory will send them instructions. The install kit has the brackets, wiring and speakers, for about $225 to $250. They have experience in installing L series radios but apparently not for the B series. Seems their market is mostly the BX line or the larger machines.
Thanks everybody for the input. Looks like I'll just have to tear into it myself and see how it goes. Kuboat never called me back. I guess I'm not a squeeky enough wheel...yet. One suggestion I liked was to take the lid off the cab instead of dropping the headliner. So... I got out my trusty Kubota manual and there was details of removing the airconditioner, but only showed you how to do it AFTER you had already removed the cab lid! Funny....not one mention of how to remove the cab lid in the entire manual. It doesn't look very obvious either.
Oh well....
   / B3030 HSDC AM/FM/CD player installation #10
Martin:
When I was discussing this with the dealer they said that if I used any radio other than the factory radio I would have to cut off the connector and manually connect the wires from the radio to the cab wiring, without really knowing which wire went where between the radio and cab wiring. They also got back to me and stated that kubota would not send them installation infomration without the kit.
I'm interested in how you make out, please keep me infomred, and if I get any further information I'll post. Im planning a trip to the dealer mid to late this week.
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2013 JOHN DEERE 470G LC EXCAVATOR (A51242)
2013 JOHN DEERE...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
