B3030 Help with Decision
   / B3030 Help with Decision #11
Seems to be a lot of talk about the B3030. I too am considering a B3030. Just sold my NH TC21D today because I wanted more horses, and please don't anyone trade down, I'm sure that would have something to do with physics and cause some sort of axis destabilization. Anyway, I have been going back and forth between the B3030hsc and the JD 3320 cab. However I was speaking with the woods company today regarding a quick hitch for the FEL and they said they don't make one because the B3030 is considered a light unit. I want to do snow plowing with a quick attach blade in the comfort of a heated cab, but the woods rep said that the B3030 was too light of a tractor and hence lighter FEL which would be easily damaged by plowing snow and hitting something unseen in the snow. I also saw somewhere else in the 40 million posts that someone felt the B3030 was a light unit. I just got rid of one unit that I felt was too small I don't want to make the same mistake again. When I was talking with the JD dealer he also felt the B3030 was a lighter unit and that the 3320 was more in line with the Grand L series.
I'm mowing 7.5 acres, plowing a 200 ft drive way, planning on doing some food plots, not sure about a BH but don't want to discount it. The Woods rep also said they do have a BH for a Cab 3030 but felt I would be better served with a heavier unit JD3320, Kubota L series, NH TC40DA due to the plowing and BH. He also said the 3030 is too light for front forks and that if I ever needed to use forks or like attachments in the future the 3030 is too light and won't lift them.
Would the MMM have to come off the 3030 to install a BH? I saw where it was posted that the BH has an undercarriage hookup.
I would really like to have the quick hitch for taking off the bucket and installing a plow blade.
   / B3030 Help with Decision #12
I own a B3030 and I like it a lot. That being said, I do agree that it is a "light" tractor compared to the Grand Ls and the the JD3*20s. When I was tractor shopping 2 years ago I was deciding between the same two tractors as you are, less the cab. I ended up with the B3030 just because it was lighter than the the JD. I have 3.5 acres with 1.5 acres of finished lawn and lots of trees. I also plow snow. The B3030 is plenty for me. I felt that the JD was too big and heavy and not really good for the lawn. I still feel that I made the right choice. From what you say, I think the JD would have more upside advantages for you. It is a larger frame tractor and the 300 series loader is a bit more capable than the LA403 on the Kubota. Bigger is usually better if you can use it. The JDs are nice but I would also check out the new Grand Ls. The 40 series really has some nice features and there are several loader options available as well. Good luck and have fun shopping.
   / B3030 Help with Decision #13
Thank you ToolGuy:
I thought I had this all worked out. I had visited the JD dealership a few weeks ago, with the intent of taking some green paint home, but left with a :( because the cost was so much more than the B3030, and at that time thought I had reached the second "Final Answer" (purchase the B3030) until I spoke with the Woods Company. I havn't priced the Grand L series yet or the TC40DA but I have to believe they're in the same price range as the 3320.
   / B3030 Help with Decision #14
When I was shopping the price difference was about $2000-2500 more for the JD3320. I never did get down to an exact price on the JD because I decided it wasn't what I needed. What prices are you getting now?
Another option to consider is a L2800 or L3400. They are the next step up in size from a B3030. They are not deluxe models but seem to have all the features you would need.
   / B3030 Help with Decision #16
I just left the NH dealer looking at their TC40DA with a Cab, FEL, Dozer Blade and Rear Finisher Mower. $36,000:eek:
Then priced a TC34DA with no Cab, FEL, MMM 72'', Dozer Blade. $28,000:eek:
The JD3320 with cab, FEL, Dozer Blade, MMM 72".
$28,650:rolleyes:
Just called the Kubota dealer for a quote on a Grand L 3240 outfitted same as the JD3320. Will get quote on Monday.
   / B3030 Help with Decision #17
If you plan on mowing your lawn with the tractor, you shouldn't go any heavier than the B3030. Otherwise, no pressing reason not to upgrade size & weight to the GL3240 - you'll still get the "premium" features of the B3030 (and then some).
   / B3030 Help with Decision #18
Doc, it sounds like you want a tractor that's light on the lawn and heavy on the snow....plus comfortable all year round. 'Most anything you find will be a compromise and less than ideal at one or the other. The comfort part will make whatever you choose fairly expensive. I think the B3030 comes fairly close to your ideal, but, as you point out, is something less than a heavy duty unit. The smaller Grand Ls will be tough cookies, but beasts on the lawn.
Personally, I think you just sold the best solution to this dilemma. The TC21 for the lawn paired with a Grand L or an L3400 for the heavy work would've been ideal. As for the comfort.....wellll, that's where you tell the wife that you're willing to make sacrifices and endure hardship ;) in order to have the right tool for each job.
It sounds like your machine will spend much more time mowing than moving snow, so that's a big point in favor of the B3030. Working on the basis of the B3030, then, it might be worth considering a snow blower over a front mounted blade. This will take advantage of the B3030's horsepower and not demand so much in the way of structural beef. If you get the cab, you'll have shelter from flying snow and wind and be able to work in comfort. With this approach, you still have to choose whether you want a front mount ($$$) or rear mount blower. Rear mount would let you retain use of your loader. I still think the B3030 is your best choice; but you may have to revisit the front blade idea....front blades are for 4WD pickups IMHO.
FWIW
Bob
   / B3030 Help with Decision #19
For BizDoc,
Just to cloud the issue...you used the word "light" seven times in your post which made me think of the other orange tractor, which is not light, so I hear. Have you looked at a CK series tractor?
Of course, your lawn may suffer if soft & sensitive.
I don't own one of any flavor and hated to mention the other orange in an original orange thread....but I like livin' on the edge. Heh.
.02
Tony
   / B3030 Help with Decision #20
Bob:
You're exactly right. I want the best of all worlds, and it's driving the Kubota guy crazy. I've been to see, and called, him so many times that I can hear him groan when he hears it's me. I just find it hard to believe that I'm the only one who wants this combination of things. The NH dealer said they have been trying to get NH to make a tractor like I'm looking for, and that he has lost several sales due to not having a smaller unit, i.e. a TC33DA, with a cab. I want this next tractor to be the last. I was hoping the TC21D was going to be it, however It didn't take long till I saw that I needed more HP. Not that it was a bad unit, not at all, quite to the contrary it was a great tractor. I don't have all that much ground, only 10 acres, but that's enough to get into bigger jobs than 21 horses will handle, even if they are self imposed. Thank you Bob.
Tony:
I only use the term "light" because that's what I have both read in some of the forums, been told from JD, NH, Woods, and even today Kubota. I want heavier arms with a quick attach, and if I ever want to lift loads larger than 800 lbs with palet forks, I'll need a bigger unit. but Yes I have looked at Kioti, in fact I was impressed with their units at the recent Pa Ag show. So I called the dealer from the show and was actually seriously considering the purchase of their 45 horse with a cab (as you're probably already aware the 45 is the smallest Kioti with a cab). It was a nice unit and the cost was about $27,500 with the cab and FEL with quick attach. The axels are very beefy and the loader lifts very high with a nice roll. I was close to being convinced until I found I couldn't get a MMM. they do make one but the dealer said he wouldn't sell me one because he felt the Kioti MMM units are of poor quality. We talked quite a bit about the Rear Finish Mower, but in the end I really like the MMM, I'm sure that's an entire forum of debate all of it's own because I have spoken with both sides on this issue and each side is passionate about their personal like, beit MMM or RFM, I quickly learned just to nod my head and listen on this topic. This is one of those issues that seems to crop up on every unit I look at, the MMM seems to limit the use of some other attachment due to the underbelly mounting system, which is used for multiple attachments. I really like the Idea of being able to load mow and drop the mower unit, but it makes the unit so long, and that extra length, seems to me, will make it hard to mow around trees that are somewhat close togeather. I also have a bank that crests to a road and am afraid of piiviting up the deck when cresting the top road, leaving the grass unmowed, or if it has the floating hinge then perhaps continuiously scalping when I go over the top. But detatching and moving a 6 foot MMM is a real chore. I better stop there I don't want to start a firestorm on mower decks.
Just love tractors, looking, riding, cleaning, talking about them.:)
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A55787)
2018 Toro Z-Master...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
